Question about HP Pavilion dv9000z Notebook
I have an HP Pavillion DV9000 that is just about 20 months old. I was using the laptop and all of a sudden the screen showed some colors and then went blank. All it does now is turn on and off. I have tried everything I could think of and it has not worked. Any help would be appreciated.
  • vjngarg1124 Jul 05, 2010
    yes but still nothing. It turns on for a second or 2 then goes off again. It keeps repeating this except when I hit F8 or F10. When I hit the F buttons it stays on but the screen is blank.
    I can't even get to the bios. The screen is black. external monitor will not work either. Had it working for a few minutes last night and then screen went white with a bunch of little squiggles. Now I have the same problem again.
  • 3 Answers
Hey, this is a know issue with the dv9000 and other dv series laptops from HP and Compaq. The problem is heat causing the video chip to loose its connection, basically. You can read more at www.hpblankscreen.com You can also send it for repair for $49
Posted on Jul 13, 2010
    President:
  • 1,768 Answers
1.Have you tried another power adapter and or battery?
Posted on Jul 05, 2010
  • Harleen Nash Jul 05, 2010
    check your BIOS setting it may be in "sleep" mode.
My hp laptop TPN-C126 has power but its screen was totally blackout
that TPN-c126 is not the model number
In fact its the EPA/EU, power (sleep )and energystar
regulations RMN:TPN-C126 (the R means gov. regs)
proof here:
http://h22235.www2.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/europe_erplot3_notebo_201542919128520.pdf
if you look again at the back of pc. base.
on the right side of where you where looking
is a SERIAL.(I dont want that)
then below that, is model
"HP 255 - G5" (or very close)
when posting use real names and models
as seen here
http://partsurfer.hp.com/search.aspx
click Hierarchy
then notebooks
then hp notebook PCs
behold. photo below.
one is yours, matching words on bottom of your PC.
LT black screens
http://pcdied.com/black-screen.html#Laptop
below is your pc if you knew its real name.15cdf60c-9764-4e4a-a480-66af380fe0ab.jpg255-g5-hmzm4reoidw0tx1unypabkrd-3-2.jpg
Jul 21, 2017 | HP Computers & Internet
Hp pavillion g6 laptop repair screen comes up and then goes black
boot your computer under safe mode by pressing F8 upon restart, repair option page will come out, locate by using arrows and enter to select. look for "last known good configuration" and select.
let it start to windows. and see if your problem solve.
thanks
Mar 23, 2014 | Computers & Internet
I have a HP pavillion dv6 that I've had for about a year and just today while working online the screen suddenly changed colors. It's not inverted but some black colors are a solid red, some whites have...
ASAP (and the caps are intentional) get your laptop connected to an external monitor. If the display is fine on the "big screen", it's most likely you only have a screen inverter/lcd failure. Failing Inverters can cause the effect you're seeing as well as an LCD burn out on the way.
If the displays are identical, then your video card is about to fail.
At least you'll know, and know right away.
Best Regards,
Marcus (laptop specialist)
Sep 27, 2010 | HP 510 Notebook
HP pavillion entertainment PC has blank screen. I
Hi there from reading your whats you wrote this tell's me that your computer screen has gone bad. Because you are using a laptop you cannot change the graphic card,for you to solve this problem you need to change the screen.
May 19, 2010 | HP Pavilion dv6000z Notebook
Screen is disclored.Shows pink instead of white.
Possible bad connection on the LCD cable. Check and reseat the cable on both end( the cable to the laptop and the cable to the LCD panel). If that doesn't work you will need to replace the cable.
Jan 15, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Display freeze then colors became crazy
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
What to do when I dont get the LCD display in hp pavillion tx1000
Hi
did you see start up screen if not then just clean your RAM & remove your battery & plug in then try if u face same problem then send me more details
Harry
Jul 15, 2009 | HP Pavilion tx1000z Notebook
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Green Blob and Fading to White
Hi, i understand ur problem and try to the following steps. Shut down the NB and turn it on and repeatedly tap F10 key until you see a blue screen and then tap F9 key once and load the bios defaults. Wait for some time and check if u can see the lines and the green blobs. If u still see the same on the screen, it means that there is some problem with the mother board. If u have still warranty left on the laptop, contact the technical support of HP so that they will take the laptop for service. This will definitely work
Thanks and Regards
Honey
Jan 12, 2009 | HP Pavilion dv6000z Notebook
Iverted Screen Color on my HP laptop
hot4teacha,Great name.
By inverted colors, could you explain a little better?
Do you mean it looks like an x-ray?
Jan 18, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
230 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
