Question about Rowenta DX6700 Iron
Rowenta Professiona Iron does not get hot - keeps ticking. is it the cord or heating element?
SOURCE: Rowenta Iron
go to home depot buy s single srewdriver or a multy size set.
 or wal-mart
Posted on Oct 14, 2007
SOURCE: Rowenta Effective Iron - Model DX1700-U1 NRB01-01
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
Posted on Sep 14, 2008
SOURCE: Rowenta iron DX1700 not heating
I hate to say this but I came here looking for solutions and it seems the solution is not to buy this Rowenta overpriced products.
Posted on Dec 30, 2008
wizzard8955
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
heatman101
  • 43501 Answers
SOURCE: I have a rowenta advancer DZ9080 iron that the
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
It is a Rowenta Professional. It won't heat, the light will come on but the iron does not get hot. When I put water in it the water pours out the holes due to it not heating. I have had it for about 5...
Possible that the heating element is open. You will need to check the continuity of the element, make sure that the thermostat is contacting if not remove and reset if the element is good. The power cord is good as the light comes on.
Feb 25, 2011 | Irons
We have a Rowenta iron effective model DX1700, less than a year old. It will not heat. Is there an iron made that will give satisfactory service for more than a year? Are they repairable?
If the cord and plug are ok (the wires in the cord often break just at the cord protector at the iron) the most likely other problems will be the thermal fuse(s) or the element. Thermal fuses can be replaced but if the element is gone that is unfortunately that. Take the back cover off and check for continuity from the plug to the inside connections using a test light or multimeter (the iron is of course unplugged).
Jan 19, 2011 | Rowenta Irons
Rowenta iron will heat up and then shut down. Have to keep plugging and unplugging the iron.
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Mar 12, 2010 | Rowenta Professional DM890 Iron with Auto...
My iron will not consistently get HOT.
Hi.
The clicking sound is given by the solenoid that turns on and off the iron element. Heating cannot be turned on, and the iron keeps clicking without making any heat.
The cause of the problem can be a defective solenoid, a broken contact, or an open thermistor (it will turn the solenoid back on). The oven must be taken apart and tested to find the fault.
Regards.
Mar 02, 2010 | Rowenta Irons
I have a DX 6700 that does not come on when plugged into the outlet.
Hi.
Either the wiring to AC power line is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
If the power cord is fused (like for example in UK), check also the fuse in the power cord, try replacing it.
Regards.
Jan 17, 2010 | Rowenta DX6700 Iron
MY ROWENTA IRONING CORD GETS HOT
This is probably caused by a connection inside the iron which is arcing. Should be disassembled and all connections inspected for heat damage. Repair connections as appropriate.
Charlie
Aug 20, 2009 | Rowenta DG-920 Iron
My iron does not heat.
check cord,plug, thermal fuse , element, and switch
Aug 17, 2009 | Irons
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
Rowenta DX6700 Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
