Question about Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR
Where can I order a new hollow gasket for the door?
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
GE fridge magnetic strip in right hand door needs to be re-installed, how can i do that?
The magnetic strip (very dark brown) is usually embedded inside a similar square hollow tube all the way around the door gasket. For it to have come out, there has to be a cut, slice or hole in the outer coating of the gasket. Press all the way around the gasket and you should feel the hollow spot where the gasket came out. It will feel solid where the magnetic strip is still in there.
Apr 04, 2015 | GE Refrigerators
Replace hollow gasket vista-pivot ii shower door
Usually the bottom of most framed doors has a chanel which contain door sweep or hollow gasket,all you have to do is pull it and slide the new one in the same place.
Please note that some times the end of the chanel is crimped to prevent the gasket to move in and out of the track.
I hope this will help.
Nov 30, 2013 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Frigidaire mod.#affu2067ew2. Gasket snug and clean. Exterior door is very cold alot of condensate. Gasket is dry but door is wet.
sounds most likely didn't get a good fill in the foaming machine the fills the door cavities wiht insulation. I've been in a refigerator plant and seen it happen. They are supposed to be checked. Tap various places around the outside of the door to see if there is a hollow sound. It could just be around the outside edges of the door unless the whole door is cold.
Nov 18, 2013 | Frigidaire Freezers
I have a Sterling 1500D Shower door and I need to replace hollow gasket at the bottom of the door. Where do I purchase this from???
It sounds like you need the sweep or seal that keeps water in the enclosure. You can buy these items, which are inexpensive and usually easy to install yourself at www.technologylk.com Technology LK carries a comprehensive range of shower door gaskets, seals and other hardware. If you have any questions about exactly what you need and how to install it, you can contact the company at www.info@technology.com or call them at 888-663-9830.
Jul 10, 2012 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a Sterling 1500D shower door, the door has rubbed against the hollow bottom seal and ruined it- I can re adjust the door, I need the part number for the hollow seal kit.
I have the same problem. I'm doing research today, I'll keep you posted. unless you already figured out where to get the seal, please let me know.
Nov 20, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I need to change the freezer seal on my refrigerator. But they did not send me any directions on how to do it.
most of these have a hardened plastic female channel thats tough to see . it is a part of the door and consealed under the old gasket. it has a hollow groove . usually the new gasket has a flat side with a dart or double dart piece sticking out . this dart or arrow side runs the entire side of the gasket and smushes into the door groove channel.. usually you start on a corner firmly pulling out the old dart and gasket from the channel groove. clean the old channel with mild detergent and a little brush. wipe down. lightly oil door groove channel with a little veg oil on a rag and get ready to mash the new dart onto the channel all the way around. it takes great finger strength and mashing one thumb on top of the other to get enough pressure but it can be easy on some. good luck .be sure to clean door sill mating surface and wipe with oily Veg oil rag so new gasket stays clean and doesnt stick. it may take a few days to break in and level out. be sure your snug all around when done. lay out new gasket nice and flat in warm room before you start.
Oct 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
I NEED HOW TO INSTALL A gasket ON THE DOOR OF A HOTPOINT, GASKET WR24X450.
look at the door gasket, look underneath the gasket and you can see how it is attached. either with a clip or the plastic itself is the one holding the gasket. unscrew all screws holding the gasket, order a new one and install backwards. if there is no screw, there is a grouve in the plastic wall where you can insert the gasket. just slowly pull the gasket and push the new gasket in to the grouve.
Feb 15, 2008 | GE Hotpoint Top-Freezer Refrigerator
Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR Logo
393 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
