I need to know if the Kenmore slider/casement ac I purchased needs to be plugged into a 110 or 220 outlet. the serial # is 580.75123700
    President:
  • 3,085 Answers
110V AC
Posted on Jul 05, 2010
Icing of cooling coil
Cehck you filter make certain it is clean .. its normal to see ice on the coils esp during real warm humid days .. I don't think you have much to worry about .. let me know if it gets sorse though > Hope this helps .. Jon
Jul 24, 2011 | Kenmore Slider/Casement Air Conditioner
A/c only works on 1-speed,why?
Check with your supplier for the model, may be having only one speed.
Jun 01, 2011 | Kenmore Slider/Casement Air Conditioner
I bought a casement kenmore from sears in 08 model 500.75123700 12,000btu's. yesterday it was working perfectly. turned it on this morning before going to the store. upon coming home it was blowing just...
most likley the compressor capacitor .unplug the unit remove the knobs by pulling them off..take screws out to open cover behind switches ..inspect wires first look for burnt or broken connections if all looks good /look for the capacitor it is silver /round or oval shape .look to see if the top of capacitor is bulging or leaking acid/this part helps the compressor start replace with new ..let me know ..good luck/joe/
Aug 26, 2010 | Kenmore Slider/Casement Air Conditioner
I've had this maytag 10000 btu slider casement air conditioner for approx 3 years. its installed in a window & has been used possibly 10 times. the fan motor comes on, however there is no cooling...
Check the thermostat, does it open and close (electrically)?
In the past three years, has the unit been cleaned? If the coil is plugged with dust, there may have been serious damage to the comressor.
With the unit unplugged, using a multi-meter, is there continuity between the switch hot tab and the compressor feed?
Is there a run capacitor on the compressor? If so, is it shorted or open?
These will give you a few places to start. If you do not know how to operate a multimeter, you need a contractor. Another option is to check your phone book and look for an local refrigeration school. Often, these schools will do the repairs if you pay for the parts.
Jul 19, 2010 | Maytag 10000 BTU Slider Casement Air...
Ac is noisey and blowing water in the house.
Hi, The drain hole is plugged by dirt and/or dust....
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 16, 2010 | Amana Casement Slider Air Conditioner
My air conditoner was purchased brand new in 9/09 and I used it approx. 1 week. It has been off all winter and I went to turn it on and it won't work.
Since it worked when you first got it and it's brand new - I would check the electrical breaker that it's on.
Sometimes a breaker will trip for no reason.
An easy way to do this is to plug something else, i.e. a hair dryer into the outlet that the AC is plugged into.
If the hair dryer does not work you know your problem is with the breaker.
If it (hair dryer) does work - then it's a problem with the AC which would surprise me - since it's a new one, and it worked before.
Good Luck!
May 07, 2010 | Kenmore Slider/Casement Air Conditioner
My kenmore 12k BTU window unit will not turn on and behaves the same way as if unplugged... no sign of ''life.''
Hi, check house panel circuit breakers or fuses, check receptacle/outlet. if you got plug/receptacle, check for reset button, press reset. if there's power at receptacle, could be faulty circuit board. good luck
Sep 10, 2009 | Kenmore Slider/Casement Air Conditioner
I have a kenmore casement model number 25378066890. I can clean the filter easily but I want to get behind the filter to made sure the front of the coils is dust free. How do I remove the cover to be able...
you have to remove the unit from the window and unscrew the cover which will allow you to clean the inside of the evap and condenser coil and oil the fan motor if it has oilers the easy way to clean it is to take it to a self use car wash. do not use the strong spray as it can bend the fins.
Jul 08, 2009 | Kenmore Slider/Casement Air Conditioner
Plug gets red hot on A.C. after 1/2 hour running.
Local hardware store would have replacement plugs and yes that would help the situation out. But the problem may lie inside the actual outlet also. So you may want to investigate the problem alittle more unless you have already done so
May 21, 2009 | DeLonghi CF210 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
