We turned on our 5 yr old toshiba plasma tv today and there is a 6 inch long green line at the top left side of the screen. It is there for every input. Any ideas on what is wrong?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with Z-main however, Z-buffer and the logic board should also be checked. These boards are located on the left side of the unit and to check them you’ll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors.
All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
I HAVE A LG50PQ30 PLASMA TV,WHICH IS JUST OVER A YEAR OLD AND OUT OF WARRANTY. AFTER THE TV HAS BEEN ON FOR A FEW HOURS THERE IS HORIZONTAL LINES APPEAR ABOUT 6 INCHES FROM THE TOP OF THE SCREEN IT STARTS...
Hello that's a 2010 model set. It sounds like the y sustain board is failing (part # EBR61855101), it usually starts with bad connections on it. A screen shot would be helpful...thanks
Apr 28, 2017 | LG 50PX5D 50 in. Plasma HDTV
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Lines in screen
They are stuck pixels...
There are some that say sending strong images that change from to color to color can help unstick them, but I say only dissassembly and cleaning of the contacts (there should be 2 ribbon cables, one for top, one for side) that probably got dust in it. Call it in under warranty if at all possible.
Apr 19, 2009 | Sony KDL-52XBR4 LCD Monitor
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
