Question about Dewalt D25600K Electric Rotary Hammer
D25600 does nothing when i pull the trigger
Dewalt hammer drill d25600 does nothing when i pull the trigger
    Master:
  • 501 Answers
Take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Posted on Jul 05, 2010
D25600 not hammering
Could be that it needs a new seal on the piston. Sometimes the piston tube is worn out also
Jun 18, 2013 | Drills
Drill not running at correct speed
Check for a speed lever on the case that changes the gear ratio from high to low speed There is a button in the front of the trigger and it limits the amount of pull you can give the trigger which controls the resistor setting in the trigger switch. Turning this will alter the speed when you pull the trigger
Nov 03, 2012 | Dewalt DW005K Rotary Hammer
My d25650 runs very hot and releases a little bit of smoke. Will replacing the brushes take care of this problem
Probably not. The heat and releasing smoke part is concerning. When brushes fail either one of two things happens. Either the tool just quits or if worn down far enough it can short out the armature. You may have a bearing (possible armature bearings) getting ready to lock up.
May 13, 2012 | Dewalt D25600 K 1-3/4" Sds Max Rotary...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Only full power for full trigger pull
I had same issue with Metabo hammer drill. It was faulty triggrer. Replace it and it shoul be fine.
Juraj
Jun 04, 2010 | Dewalt DW056 18 Volt Cordless Impact...
I have a 1/2" Dewalt corded hammer drill, and it w...
it more than likely needs a new switch, to to Dewaltservicenet.com and you can download a breakdown with parts list.
May 21, 2010 | Drills
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Drilling slowly
If the battery is OK then the problem will be in the variable speed trigger switch.
Sep 24, 2009 | Dewalt DW999K 7/8" Cordless SDS Rotary...
Dewalt D25600K Electric Rotary Hammer Logo
295 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
