Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Our Bissell Proheat began to make a strange sound and smell hot. We checked the brissels and at the end of one it had melted where the teeth are for the belt. We reassembled it and then the motor for the brissels made no noise and would not turn the bristels at all. What happened and how can it be fixed?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 23, 2010
My Bissell Proheat 2x, is putting down the solution fine but it barely pulled up 1/4 of water and I went through 2 bladders. We check the sucking action under the brissells and it was very weak.
Make sure you switch suction from hose to front nozzle
Check seal between front suckin nozzle and top lid is ok
Check plastic screen (usually red coloured)located inside top lid of the container for water
Jan 03, 2018 | Bissell Vacuums
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
We have a Brissell 12amp preheat pet shampooer and the roller on the bottom are not turning we checked the belt but it seems fine. so we're not sure if there should be 2 belts or one . and what would be...
Bissell Proheat has two belts. A stretch belt goes from the motor to the pump and a geared belt goes from the pump to the brushroll. Both belts should be replaced once or twice per year.
Oct 23, 2013 | Bissell Vacuums
Brissells won't spend
heatman101
Oct 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Need a manual for pro heat brissell model 1699
heatman101
reyy536
Mar 05, 2010 | Bissell 1699 ProHeat Clear View Upright...
Front brissels dont rotate
have you removed the bristle bar to see if carpet fibers have wrapped around the ends causing the bar to bind up, have you noticed any smoke smell, if so your belt may have broken, easy way to check, flip the unit over and remove the bottom cover plate, whats wrong should be obvious at that point.
Dec 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat belt won't turn, and belt snapped
The brush roll is probably melted to the ends. there is a new brush roll ***'y with new ends. more reliable than old design. usually happens because floor is not vacuumed well enough and too much hair is left on carpet which winds around the roller and melts the end.
J
May 19, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
106 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
