Question about Sharp AF-M808X Air Conditioner
There is a large amount of water dripping from the unit. The hole at the bottom of the unit is clear. Is ther some kind of hose of ?? that may be clogged? Thank you
  • 6,826 Answers
It is most likely normal,this is because of the heat.
Posted on Jul 05, 2010
  • johnlazcano Jul 11, 2011
    Ok hear we go I just fixed this on my unit and the comment above is lame. Your unit has a plastic front cover in addition to the cover for the filter that must come off. Unplug the air conditioner and pull it out of the window. Pop out the plastic filter cover and dust filter. Look at the front of the AC unit. There is another plastic cover with 3-4 screws that must come off and also remember to remove the 4 screws around the digital control. Carefully pull the plastic front cover off. BE CAREFUL OF THE LITTLE SLIDE FOR THE OUTSIDE VENT. DO NOT FORCE IT. The main front cover has two clips at the top that can be a pain in the rear, but hinging and wiggling it should pop off. Try not to break the plastic or bend the casing where the cover clips in. Slip the digital control sideways through the hole it sits on top of when you pull the cover off. Be careful throughout with this control you do not want to mess it up, yank on it or get it wet. In fact you do not want to get any wiring on the left hand side of the unit wet, so be careful. Also do not bang up the metal radiator on the front or back of the unit. Those fins are important. Now you have to remove the metal cover from the sides and top of the unit. It is in one piece. There are 3-4 screws on each side that run along the base (I think there is an extra screw on the left side too don't miss it) and two on the back. The metal cover should pop off upward nice and easy. Be careful not to break any Styrofoam, tubing, wires etc. Now you may be looking at the unit and thinks how the heck am I going to find the clog (just as I did). Get a flashlight and go to the right hand side of the unit and peer into the dead center of the unit and you will see a little V trough at the base/back of the Styrofoam. The trough is basically in the center (looking from above) of the square that is the unit. This trough is where the water drains from the front coils and their Styrofoam base. It is most likely clogged with muck. Get a hose or pot with a handle and flush the area with hot faucet water over and over again. The area that you uncovered can be well sprayed or flushed as it is the end that is rained on and exposed to the outside wit the metal cover. Make sure you flush that V trough and the entire back end of the unit. You can also flush out the front coils, BUT DO NOT get the digital control or the wires wet on the left side of the AC unit. Make sure you flush out all the junk in the back. Algae, leaves and dirt will re-clog the drain. If you can stick a hose in the V trough all the better, but make sure you do it right the first time or all of this is for nothing and your unit will be dripping again. If you can flush water in the front coils and watch the water drip out the hole in the bottom of the AC (unit must be flat and at an angle), all the better. Now put the metal cover back on and tighten the screws. Feed the digital control through and put the front cover back on top clips first. Tighten its screws on both the cover then the controller. Pop the filter in then the filter cover and plug the unit back in. Press the power button and cross your fingers hopefully you cleaned out all the gunk with the hot water. And the water runs out the drain now.
Maytag Fridge MFF2558VEM is leaking water from bottom of unit. Suspect a clogged drain hole. Need to access the drip pan and clear drain hole. Drip pan is not behind the toeplate grill at the front
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Sep 11, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Sounds like dripping water when on
Water, or in this case - condensation will be created and drip from the cooling coils inside the unit outdoors, if installed correctly. This is a normal condition. Like a cold glass of water sitting on a table or counter on a hot, muggy day; condensation will form. The amount of condensation forming on the glass - and cooling coils of the A/C - is directly related to the amount of humidity in the air.
Some A/C units have fans that not only force cool air out the front of the unit - but also spray condensate on the condenser coils (the coils that get hot and are visible from the outside) to help cool them down.
If water is dripping indoors - the A/C is tilted inward or drain holes on the bottom edges of the rear (outdoors) are clogged. Adjust the A/C support(s) so that it is tilted back (the bottom rear should be about 1/2" or 10mm lower than the bottom front) and inspect & clear obstructions from the drain holes as needed.
I hope this helps & good luck!
Sep 15, 2011 | Daewoo DWC060CL Wall/Window Air...
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
After a heavy down pour I noticed a large amount of water dripping from behind the glove box. Do I have a clogged drain?
The two drain holes in the compartment beneath the wipers are plugged with debris. Take off wipers.
2. Take of plastic panel under wipers. 3. Clear crud away from drain holes. Pour water in there afterward to make sure it drains properly..You will see it come out the bottom under the car.
4. Clean out any other leaves hope this will hlp you
Sep 22, 2010 | 1999 Dodge Grand Caravan
Water is dripping in side the freezer, and freezing at the bottom of the freezer, where is the hose , so i can check it for blocks in hose???
You have a plugged drain hose. Defrost unit then check drain hole to see if clear. These have a real problem with that. This company is out of buisness now.
Aug 28, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
I am geeting water on the bottom shelf of my
There is a defrost drain located at the rear wall inside the frig.
I usually take a large syrenge with a rubber hose attached to it. I fill it with hot water and insert it into the drain cup sealing it to the small hole at the rear of the cup. Force the hot water through the hole in the rear of the cup and this should clear anything stuck in the drain.
I hope this helps.
Dec 31, 2009 | Refrigerators
Dripping water inside fridge. Can't find drain hose
at the rear of the fridge unit there is a hole, normally at the bottom of a shallow "v" shape. there should be a plastic insert in it to clear any blockages, just wiggle it a bit. failing that a pipe cleaner will do the same.
May 02, 2009 | Refrigerators
Sharp AF-M808X Air Conditioner Logo
170 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
