Question about Sony NW-A605 (512MB) MP3 Player
Sony mp3 player won't charge using any usb port in my computer. Mp3 port is loose...took apart, don't see y it's loose
  • Sony Master
  • 17,129 Answers
Possible reason could be frequent use would have damaged the port connectivity, If there is another usb port use them or else you can clean them to se it this works. if not try to fix a USB extender which can be procured from any PC harware shop that might sometimes give a good connection , thre after do not remove this connector but use the extender port.Check to also see if your USB drivers can be reinstalled, check though the device manager/ ports. Helpful? Good day.
Posted on Jul 05, 2010
Eclipse mp3 player 4g wont charge
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
May 04, 2012 | Mach Speed Eclipse 180 MP3 Player
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
Can a charger used for a blue tooth charge a sony mp3 player as if it were connected to the computer usb port?
NO!
in NWZ series player ONLY can be charged when it's connected to PC or Laptop USB directly.no other way
May 02, 2010 | Sony Walkman NWZ-B135 MP3 Player
How can you charge SanDisk Sansa CLIP MP3 Player apart from the usb
It really needs a USB port. If your computer doesn't have a USB port, you can buy an AC adapter that will power a USB port. Check the cell phone section of your local department or electronics store.
Oct 08, 2009 | SanDisk Sansa Clip MP3 Player
Not charging
You may try connecting the Walkman to different functional USB port on the Computer or different Computers. Press and hold the Reset button for 30 seconds then try charging it. If the issue persists then you may try using a different USB cable. If the player doesn't charge even after using a replacement USB cable then service will be required.
Aug 23, 2009 | Sony Walkman NWZ-S616F MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
E280 not charging
You might have to get a new charger--But be careful. If the charger isn't made especially for the Sansa e280 there's the possibility of it messing up the mp3 player itself.
It could also be your computer's USB port. Try using a friend's computer or a different USB port perhaps and see if it works then.
Apr 07, 2008 | SanDisk Sansa E280 MP3 Player
Files will not load
Try reformatting the drive to factory defaults. I would also try this unit on other PCs to verify that the USB port will not work correctly. Does the USB port on your Sony Walkman MP3 player have any damage or broken pins/connectors on the USB port?
Mar 31, 2008 | Sony Network Walkman NW-E005 MP3 Player
Charging player/downloading songs causes computer to crash.
You can purchase a "AC to USB" power adapter for about $30
Mar 04, 2008 | RCA OPAL M4001 MP3 Player
MP3 player dead
well did you push the it all the way in the USB Port? Sometiems I don't connect it all the way and it doesn't charge. I go to my school and charge it on there computers too and it charges fine.
Another advice is to actually use the Sonicstage to avoid viruses. It's not that hard to install or download music files.
Dec 14, 2007 | Sony NW-E002 MP3 Player
Sony NW-A605 (512MB) MP3 Player Logo
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
