Question about Technics SUV500 2-Channel Amplifier
I got a system from a friend of mine that appears to be in great shape however, when I hooked it up I can barely hear the sound out of the speakers. I tested the speakers with another system and they were fine. If I crank the volume up to 'full blast' I can hear it but faintly. Its like standing next to someone who has ear buds in and the volume is too high, you can hear the tinny overflow but its not really music. I looked for something that would look like a fuse or switch on the outside of the case but nothing. I pressed the help/reset button and the text says system is operating correctly. Any advice is appreciated. I have it connected to a tuner and a cd player and the result is the same regardless of the source. Thanks in advance. System: Technics SU-G88
  • Ian Summerfield
    Ian Summerfield Jul 05, 2010
    is the MUTE on?.try the headphone socket,with headphones,sound ok?make sure speakers are plugged into correct sockets.
    New Friend:
Did you ever figure out what the problem was? i just got one and it is doing the same thing. thanks for your help!
Posted on Jul 09, 2013
Its because your sound system is too high for your speakers i thnik
Posted on Jul 05, 2010
2 Suggested Answers
Duncan
  • 218 Answers
SOURCE: I can barely hear output even when the volume is at 100%
You may have the tape monitor button pushed in or if you look on the back of the unit you may find a pre-out/main-in set of rca jacks. If you don't have a switch to bypass those jacks then you will need to use a set of 2 RCA jumper cables or some stubs made for that purpose. Hope this helps.
Posted on Apr 13, 2007
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
How to hook up my Mackie 1202 VLZ PRO to my computer .....
i think your computer audio is not in shape to boost a great sound. specially when it is built-in sound in the motherboard of your computer. see your computer / motherboard manual's if the driver's you have AC '97 then you cannot really boost sound.coz it's a generic driver's for sound card. if try also to update your driver's (sound). by seeing the brand and the model of your motherboard or computer and go to manufacturer websites for update. after update if can't help, but you really need to boast a great sound then you can really buy a PCI sound card 6 channels or 24bit 5.1 or 24bit 7.1 f your sound system have are compatible with this. or has an interface like this - audio 5.1 and 7.1.
Nov 15, 2008 | Dell Dimension 2400 PC Desktop
Great sound, no voices
Mine was the center speaker wire was not properly seating in the speaker. This is where all the sound for the voices come out. I thought it was something major. try checking them again if you haven't already.
Nov 04, 2008 | JVC TH-M505 System
Bose 123 Home Theater speakers started crackle sound?
If the wires are bare on some parts and touch eachother that will most likely be the cause.
Aug 08, 2008 | Audio Players & Recorders
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
Audio and sound while watching DVD'S
does your reciever/ amp have a pof digital input ??? i would try upgrading to digital signal before anything!!!
Mar 10, 2008 | Audio Players & Recorders
Polk Audio RC55i In-Wall Surround Speakers (can't hear whispers)
I'd make sure that the receiver surround mode is set for one of the digital settings, such as Dolby Digital or DTS, and make sure that you have the center channel level adjusted to a level similar to the other two front channel speakers. I've seen/heard this happening when using dolby digital material & having surround set on something like 'hall' or 'stadium' or dolby surround, where only 4 channels are used & the amp has to 'mix' sounds to the left & right front speakers. It'll often sound like the actors on screen are talking out of the bottom of a barrel, with a hollow & tinny character to the voices.
Jan 07, 2008 | Polk Audio RC55i Main / Stereo Speaker
Apr 13, 2007 | Technics SUV500 2-Channel Amplifier
Technics SUV500 2-Channel Amplifier Logo
174 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
