Question about Vornado 215S Air Circulator CR1-0065-04 Fan
This fan is great. I've had it for 8-10 years. And now it has developed that problem I've had before with fans: The motor will hum but the blades do not turn easily. I have to jump start the blades. Can I do the repair or must I chuck the whole thing. It's a shame because of the quality of the fan. Can't I just replace the motor? And if so where can I get one?thank you.
    Master:
  • 501 Answers
Take it to a motor rewind shop.they can rewind the armature and o/haul it
Posted on Jul 05, 2010
Vornado fan switch is broken, where can I get the parts
Posted on Aug 17, 2011
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
We have several 11 year old Craftmade ceiling fans that have developed a ticking sound, mostly on the medium speed. Is there a way to lubricate them or is there some other way to stop the ticking?
Several things besides lack of lubrication can cause the problem.
One or more of the fan blade irons may be loose. As well as the wooden blade itself. In both cases a Phillips screw driver will solve the problem.
The pull chains are clicking against the the fan. I've see this happen many times. Simply putting some tape around the chain, where it touches the fan, will generally silence it.
And last, but not least ... The fans may be out of balance. But, this may be due to loose screws in the fan blade irons.
As far as lubrication is concerned. Older unit (10 to 15 years) have sealed motors that were to be permanently lubricated. Even some of today's brands and models are too. At best, if none of the above silenced the ticking, is to use a little WD40 with a straw nozzle up into the fan housing. Be careful doing this as the WD40 may drip. Be sure the wall switch for each fan is OFF, before attempting this.
Hope this helps you and thanks for choosing FixYa.
Aug 27, 2011 | Heating & Cooling
When i turn on the fan i heer the moter but the
The motor just hums along without spinning means the armature has expanded from heat from running through the years. It is time to replace the fan or the motor if one is found at a decent price
Jun 10, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
There is a humming noise coming from fan no matter what speed it is on. I have run the fan for hours and still humming
The key to a quiet fan is to isolate the motor vibration from all other parts. This occurs, in the majority of fans, in three places: between the motor and the blade brackets, between the blade brackets and the blades, and between the downrod/motor flange and the mounting bracket. Some fans also have vibration-isolating material between the mounting bracket and the ceiling. If your fan makes a noticable humming noise, inspect it for the above mentioned types of vibration-isolating material. With the exception of the rubber flywheel, if your fan is lacking any of the above, they are easy to add and should solve the majority of humming problems. You can always add additional material as rubber washers and spacers are readily available.
Jun 09, 2010 | Hampton Bay 52 In.Carriage House II in...
Outdoor unit hums but fan doesn't turn. Nothing heats up but the fan just won't turn and is there a spot to oil the fan on the motor
The fan motor on the outside unit should be a sealed motor. If the unit is just humming is the humming from the compressor or from the motor being locked up. You could try spinning it a few times with the power off to see if this might get it to run and spray some penetrating oil under the fan blade right where the shaft comes out to the fan blade.
Dec 24, 2009 | Heating & Cooling
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Light works, fan does not. Fan motor has low hum but blades don't turn
How old is this? The motor has failed windings and carries a pretty long warranty I believe 25 years was the norm? eric
Jul 02, 2009 | Hampton Bay 52 In.Carriage House II in...
I PURCHASED THIS HB CEILING FAN (52" KEMPER) ABOUT A YEAR AGO AND ITS WORKED GREAT. BUT ALL OF A SUDDEN IT JUST QUIT. I HAVE POWER TO THE FAN BUT IT WILL NOT WORK FROM THE REMOTE OR THE WALL BUTTONS. WHAT...
does the blades rotate?or just humming?either way,clean and check for possible capacitor blow-up.if not , then the motor is defective.have tech for mano y mano analysis.
May 15, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Nov 18, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Vornado 215S Air Circulator CR1-0065-04 Fan Logo
1,038 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Mack Baxter
Bill Boyd
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
