Question about Dehumidifiers
I have a Comfort Aire BHD-501-D dehumidifier that does not work.
After storing it clean all winter, I turned it on recently. THe fan goes and the compressor makes the same racket it always did. But, the bucket never accumulates any water. The unit never makes a puddle, either, so I do not think that the hose or duct is blocked. It's like a sound effects machine for a dehumidifier without the function. The book from Heat Controller said nothing about this malfunction. Can you help?
SOURCE: comfort-aire Dehumidifier bhd-651
Most likely the fan motor is broke. I have seen several units with bad fan motors.
Posted on Aug 02, 2008
  • 3 Answers
SOURCE: Fault Codes
This is more of a tip since I have not actually fixed anything yet. As a test, remove the upper front cover where the buttons and displays are. (2 screws on the bottom then pull off a the plastic snaps) Inside the case on the far left, there is a piece of crimped copper tubing, open on the top end, welded to the refrigerant line, with a black sleeve covering 2 wires out the bottom end. This is a thermistor. I CAREFULLY applied heat with a butane lighter (the mini torch kind, not the "candle flame" kind), taking care not to burn anything. I applied ONLY enough to make it slightly warm to the touch. Do not think of melting anything, as this is not the purpose. Applying too much heat could damage the thermistor. With the bucket in place, the unit started right up. After I did this, it failed again in a few minutes, so I heated it again, and thus verifying it as the source. I have done it a third time, never getting it much over room temperature, and it is still running after almost an hour after doing nothing else. Since this temperature sensing is an analog function to the microcontroller that runs everything, the fault could be any bad connection or solder joint along the way from this thermister to the controller. But is sure appears something in thermistor. I hope my description is complete and clear. Good luck.
Posted on Sep 16, 2008
SOURCE: motor
Your problem may be the thermistor that causes the CH01 trouble code.
Posted on Sep 20, 2008
heatman101
  • 43501 Answers
SOURCE: My comfort-aire dehumidifier #BHD-301 just stopped
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Comfort-Aire BHD-301 dehumidifier that
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Posted on Aug 17, 2010
Fan doesn turn
test the voltage at terminal of the fan, if there are according to the plate name of the fan, the FAN is faulty, replace it.
God bless you
Oct 01, 2013 | Comfort-Aire BHD-501 Dehumidifier
My dehumidifier model BHD-501-D is icing up. The fan and compressor are running, do I need a new thermostat?
You may, but more than likely, the air intake filer needs to be cleaned and the compressor coils wiped down and cleaned. After cleaning the coils, a light coat of WD40 helps to preserve them.
Before attempting any cleaning or service work, turn the unit OFF and unplug it from the wall outlet and allow it to thoroughly thaw. Keep in mind, a dehumidifier will freeze up, if the room temperature is below 40 degrees. Also, where you have it installed may be a problem. Particuarly, a basement. Where the air temperature is colder at floor level.
In case you have misplaced your Owners Manual, I have included a link to it that you can download & print for future reference. Be advised, your Model Number is not for a Sunbeam Dehumidifier, it's for a Comfort Aire dehumidifier that's manufactured by Heat Controller Inc.
http://www.sylvane.com/images/prodphoto/co758/comfort-aire-product-manual-501-651-D.pdf
I hope this helps you solve the problem. Please let me know. Thanks.
May 07, 2011 | Sunbeam 30Pint Dehumidifier
Hi my comfort aire dehumidifier is brand new. It was working fine controlling the humidity and the reservoir was filing with water. All at once, it acts like it is contolling the humidity, but there is...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Apr 10, 2011 | Comfort-Aire BHD-501 Dehumidifier
The fan on my dehumidifier is no turning when I turn it on.
heatman101
Jan 01, 2011 | Comfort-Aire BHD-501 Dehumidifier
My dehumidifier model bhd-501 won't shut off& is very hot. What might be the problem? Thanks
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Jun 18, 2010 | Comfort-Aire BHD-501 Dehumidifier
Runs constantly and doesnt collect water.
Fan turning?
Coil frozen (low on refrigerant) ?
May 19, 2010 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Apr 20, 2010 | Comfort-Aire BHD-501 Dehumidifier
Comfort aire overtemperature switch part no. 47-21900-01 I am looking for this part. thanks stew
Call Heat Controller in Tennesse they distribute this although it is made by LG
Jan 22, 2010 | Comfort-Aire BHD-501 Dehumidifier
Motor
Aug 21, 2008 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
