Question about Sony Cyber-shot DSC-S600 Digital Camera
How do you turn the flash on and off?
The flash isn't working on the camera - how do I turn it on and off?
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
Jan 10, 2018 | Sigma EF-530 DG ST for Pentax TTL Flash
My nokia x6 camera flash isn't working anymore, i restore factory settings then the flash of the camera isn't working... plz help
This can be a hardware issue, failure of the circuit, the flash unit or the LED. In this case it is best to take opinion and support from Nokia care unless you are fully equipped to open and check and evenso the spare could be another issue.get estimate and proceed
Jun 28, 2012 | Nokia X6 16GB Cell Phone
Flash for mamiya 7
As with most cameras, the flash for a Mamiya is universal. Any flash with a hot foot connection will fit onto the camera, and function on the camera's shoe mount. You may alternatively use any flash which has a PC sync cord to plug into the PC sync socket on your camera, it just depends on whether you want to use a camera phycially mounted on your camera, or an off-camera flash.
The flash shoe on the Mamiya 7 isn't an "intelligent" type, meaning it only has the standard single contact and doesn't communicate any exposure or other information between camera and flash, so even the cheapest off the shelf shoe-mount flash will work just as well as the most expensive. Even specialized dedicated Nikon, Canon, and other brand "dedicated" flashes with multiple contact pins will also work, only the functionality of the information communicated through those other pins will be lost.
Sep 16, 2011 | Mamiya 7 II Medium Format Camera
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
Recently my Canon camera stopped taking pictures. It will take a picture if the flash isn't needed or of you turn the flash off; however, if the flash is needed, the orange flash light will come on...
If your camera is under warranty bring it to the nearest Canon Agency to have it check and repair. Most of the time the problem is mechanical and only the qualified technician can fix it.
Jun 19, 2011 | Canon Cameras
My flash isn't working, I read the manual and did everything it said. Still nothing. Any suggestions? I'm new to any camera other that a point-and-shoot.
"My flash isn't working, I read the manual and did everything it said."
Hmmmmm .....
What does the screen show?
Is the camera on AUTO?
Last resort I guess is to go where you got the camera and ask them.
Jun 16, 2011 | Fuji FinePix S2 Pro Digital Camera
I cannot get the flash to work?
Most of the time, cameras have a small button located on the top, or near the other buttons that enables the flash. If there isn't one, try looking in the options for a flash setting and enabling it.
May 04, 2011 | Praktica SlimPix Digital Camera
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
15 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
