Question about Maytag MSD2756G Side by Side Refrigerator
Freezer working fine the fridge is not
The freezer is working fine but the fridge is not cooling properly, the motor is constantly runnig, could there be a blockage in the line
  • 712 Answers
The motor running constantly means the fridge is not sealed properly so that it is losing cold to outside. Check if the door of the fridge seals properly.
Posted on Jul 05, 2010
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Fan runs constantly and freezer works fine but fridge cools poorly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Refrigerators
The freezer is working fine but the fridge is not cooling. The motor is running constantly. I did accidently leave the fridge door ajar for a few hours
Check to see if the cold air supply from the freezer to the fridge section is blocked and that the fan is running. The fridge uses cold air from the freezer to cool and many times the intake is blocked by something in the freezer compartment.
Sep 13, 2010 | Kenmore 72912 / 72914 / 72919 Bottom...
Fridge section not cooling properly
your evaporator iced up, defrost it, leave it off for 24 hours.Check defrost heater,timer, and the fan motor.
Apr 07, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Fridge freezer not cooling from new - buttons not working
Sounds like an air flow problem from the freezer section to the refer section. Check that nothing is blocking the air vents, and that the dampers are operating properly (they control the flow of air). Of course if it's under warranty... call the service techs out.
Oct 27, 2006 | AEG S75578KG Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
223 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
