Question about Microsoft Xbox 360 Console
How do i fix the open tray problem on an xbox 360--it won't recognize discs
    Sergeant:
    Champion:
  • 297 Answers
This is caused by the drive taking far too much heat and to fix it you need to stop the heat build up getting to the drive you can actually do this at home with a good guide or you can send it in and they will fix it for you.
Posted on Jul 05, 2010
    President:
  • 1,382 Answers
Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them,they may be bad.
Thank you !!
4 Suggested Answers
  • 34 Answers
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Posted on Jun 23, 2009
justin217
  • 85 Answers
SOURCE: My xbox 360 wont play discs - keeps repeating open tray.
Call microsoft at 1-800-4-MYXBOX
Posted on Jul 15, 2009
repairtech99
  • 767 Answers
SOURCE: my xbox 360 disc tray wont open how do i fix that
Slap the top of the the box as you press eject. that will get it open.
then wipe a little rubbing alcohol on the black belt
just under the tray . And a little petroleum jell in the
tracks under the tray . Then open and close the tray to
work it in.
Rob
Posted on Sep 19, 2009
Why won't my xbox read the game?
IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
Jun 13, 2013 | THQ Saints Row 2 for Xbox 360
How do i fix my xbox 360 when it isnt reading my discs
So it is the "open tray" problem then??... You will have to open your xbox and follow the instructions below on youtube, the problem is mechanical, your lazer is stuck in the far back position away from the cd so it cant read or recognize that there is a disc in the drive but it is an easy fix....... http://www.youtube.com/watch?v=ycuvX7x1HJk&feature=watch_response
Jun 28, 2010 | Microsoft Xbox 360 Console
Xbox is fine but doesnt read the game disc
This is a common issue with the Xbox 360 console wherein it behaves as if no disc in the tray. This error is encountered due to a hardware failure in the system, probably the lens was not able to recognize the disc format since it was failing. You have to contact Microsoft Xbox support to have this fixed..
May 10, 2010 | Microsoft Xbox 360 Console
My xbox 360 will recognize the game in the tray
Error code E88 it's the dice tray sensor this will not be a long solution just try ending it to microsoft if warranty is still valid and/or try "YouTube" and in the adress bar type " open tray problem fix" and follow the steps shown it will require some partsbieng removed I do not recommend this if your warranty is still valid.steph the not so expert guy
Feb 02, 2010 | Microsoft Xbox 360 Console
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
Xbox 360 wont recognize game discs
your lazer has packed in my sugestion is to buy a new one. i had the same problem
Jun 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
Open tray error
Your problem is that your Xbox 360 cd drive, the ray inside it is scratched, get a cd drive cleaner and it will be fixed.
May 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
626 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
