Question about Husqvarna Scandinavia 100 Sewing Machine
I can't get the tension right. The botton thread is always too loose.
    Master:
  • 501 Answers
Try adjusting the foot tension,or the top thread tension
Posted on Jul 05, 2010
The tension my machine seems wrong. When I sew the stitching at the bottom of the material is right but the sewing on the top seems loose.
Tighten the top tension. However, if the bobbin thread is actually pulling up on the top of the fabric, the bobbin tension is too loose. Both top and bobbin threads should pull enough against each other that they meet in the middle of the fabric without causing puckering.
Another thing to remember. ALWAYS RAISE the presser foot when threading the top thread!
Jul 15, 2017 | Sewing Machines
Can't get tension right have adjusted tension dial but when you pull the thread it just pulls out like tacking stitch
make sure that it is threaded correctly between the tension plates
correct tension is when you pull the thread as if to thread the needle there should be a slight resistance to you pulling the thread
Apr 22, 2017 | Sewing Machines
Stiches are loose how to adjust the tension
Loose upper thread requires the top tension to be increased (higher number).
When threading the top thread, be sure to ALWAYS RAISE the presser foot while threading so the thread will seat properly in the tension disk.
If the bobbin thread is loose, then the bobbin tension needs to be tightened.
Understanding Thread Tension Threads
Mar 06, 2017 | Sewing Machines
Bobbing thread pulls right out when I don't seam
Either the upper thread is not seated properly in the tension disk or the upper tension is too loose.
When threading the upper thread, be sure to always raise the presser foot so the tension disk is released and the thread can seat all the way.
Test the machine again, and if the upper thread is still looping under the fabric, tighten the upper tension.
May 17, 2016 | Sewing Machines
Can't get tension adjusted. Top loose, botton thread comes up over top fabric
bottom thread is loose, tighten the tensioner in the bobbin, (you might have to loosen the top to balance.) make sure thread was properly routed.
threading of bobbin sewing machine pictures Google Search
Oct 13, 2015 | Brother Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
The stiches at the botton are loose,it sound good at sewing but somehow it still a real mess ,no matter how i tried all different adjustment in the control bottons..
Looping on the underside is an indication that your top thread is not under tension. So you need to check again on the top threading up and make sure the thread is seated into the tension discs. Always thread up with the pressure foot raised to open up the tension device. Make sure the thread goes into the tension device, to test, lower the pressure foot and pull on the thread downwards - it should feel firm and resist pulling. If you can't get any tension onto the top thread, then the tension device may be broken.
You should not need to adjust the bottom tension at all.
If a machine is set up correctly the top tension should only need finessing by half a number at the most.
Sep 24, 2011 | Singer 5050 Mechanical Sewing Machine
Brother MB 2600
You should not have to adjust the bottom tension when using sewing thread.
There is a tiny screw on the side of the bobbin case - left/loose; right/tight.
Mark the screw head slot and edge of the bobbin case with nail polish or sharpie so you know where you started.
If you are having a stitching problem that appears to be loose bobbin thread, it may be that the machine was threaded with the presser foot down.
Always thread a sewing machine with the presser foot up.
When the presser foot is down when threading, the thread cannot enter the tension control and you get loose, loopy stitching.
Feb 24, 2010 | Brother XL-2600I
Top thread is loose
Your needle thread tension is too tight or the bobbin tension is too loose. If it is the latter try turning the bobbin case tension adjusting screw clockwise abot a full revolution.
If that does not work there is more than likely a bit of lint behind the tension spring, so carefully remove it and clean it out.
Jul 06, 2009 | Singer 2662
Thread tension for regular seam sewing
oil the shaft for the presser bar and keep moving it up and down(it may take a while) until it moves freely. Always use Sewing machine oil Not 3N1 oil.
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension). If you have loose thread on top your top tension is probably too tight and your bobbin thread too loose
Mar 23, 2009 | Sewing Machines
Husqvarna Scandinavia 100 Sewing Machine Logo
160 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
