I have a vertical flat oil Dimplex heater that is 40 years old. Although it still goes I cannot control the temprature, always on high.Is there a chance I could get hold of a replacement thermostat? Bob
  • 518 Answers
Try the dimplex web site,theyl say if they have any
Posted on Jul 07, 2010
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Jul 06, 2011 | Dimplex Compact Electric Flame Stove...
I HAVE 2400 WATT DIMPLEX BUH24T FLOOR ELECTRICAL HEATER APPROX 20 YEARS OLD WITH FUSED 3 POSITION WALL SWITCH. I AM REPOSITIONING THE HEATER AND NEED TO CONFIRM THE INTERNAL WIRING FOR THIS SWITCH. THANK...
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
May 24, 2011 | Dimplex CS3311 Compact Heater
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
May 27, 2010 | Dimplex Heating & Cooling
Dimplex OFC2009TI programmer not working
yeah i now have this problem did you find a solution?
Jan 26, 2010 | Heating & Cooling
Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Jan 19, 2010 | Heating & Cooling
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
Can i fix a Dimplex DS5603 by replacing the plug?
change the plug noting the polarity. one wire in the flat cable has a rib running the whole length, the other wire has no rib. the ribbed wire goes on the brass screw in the replacement plug. the non ribbed wire goes on the nickel shaded screw. the green or yellow/green goes on the green screw. the plug is getting warm because the spring tension in the receptacle is getting weak. any little bit of arcing in the receptacle will create heat.
Oct 14, 2009 | Dimplex Heating & Cooling
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
