Question about Whirlpool Duet GHW9150P Front Load Washer
How do I get the "Control Locked" light off. None of the controls respond when it is on.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
How do I unlock the control panel?
here you go
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked
If you have a front loader then Press and hold the "end of cycle" button for 5-10 seconds and it will reset the child safety lock.
If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, You could have a failed control console or a bad electronic control board in the washer.
Jun 19, 2010 | Maytag EPIC MFW9700S Front Load Washer
Front door wont close control locked light is on
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Controls locked
Hello
Welcome to Fixya
My name is Huum,
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Player is not responding cant shot off or on. when battery remuved it shots off
Betwenn the headphone socker and the power switch is the lock control. I'm thinking maybe your player is just locked. Try moving the switch to the other setting.
Let me know how you get on!
Jan 11, 2008 | Creative Labs Zen Micro MP3 Player
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
