Question about Danby DWM5500W-1 Energy Star 1.69 Cu.Ft. Front Load Washer
Barral won't turn
Barrel won't turn. I have checked the belt it's good, I have also turned the motor it's not locked up. Is there an overload reset on the motor and if there is where is it located ?
    Champion:
  • 274 Answers
Try unplugging the machine well the lights turn on?IS the machine empty is the door in the locked position?
Posted on Jul 05, 2010
  • meganestep Mar 15, 2011
    Did you figure out a solution to this problem? Could it be a filter? Having the same issue here.
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
Samsung dryer, model: DV317AEG turns on, but won't spin
Could be the motor is full of lint. Depending on how mechanically inclined you are take the belt off and spin the barrel and the motor separately motor should spin free, barrel a little harder to spin,but spin at least a quarter turn after letting go.
Jul 05, 2012 | Dryers
No the dryer won't start it make a hum sound but the barrel doesn't turn(I check ed the belt it is fine) maybe the starter switch you think. Chris
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Kenmore 62602 Electric Dryer
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 29, 2010 | Dryers
The dryer is getting power but the barrel isnt turning
If motor runs but no tumble, belt is broken. It broke due to overloading, old age, or bound up tension pulley or drum support wheels. You have to check all of these when replacing belt. Belt is fairly cheap.
Jul 02, 2010 | GE Profile Harmony DPGT750EC Electric...
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Barral will not turn
It is probably the motor. If it runs when you give it a little help. If it is over 15 years old, you should replace the entire unit.
Sep 01, 2009 | Kenmore Dryers
Frigidaire model FWTR445RFS Hear motor, no drumroation, no spi,
I sounds like the belt fell off. You can verify by removing the rear plate off the unit & verifying visuall. If off and not snapped then you can just simply put it back on. Otherwise replace. Hope this helps
May 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Danby DWM5500W-1 Energy Star 1.69 Cu.Ft. Front Load Washer Logo
117 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
