Question about Poulan "" Push Mower
It will start but wont keep running
I have tryied replacing the gas and put a gas water remover in
    Master:
  • 502 Answers
Tip all the gas out.drain the carbie bowl.put fresh fuel in.drain the carbie bowl till fresh fuel comes thru,retry starting.put a new spark plug in
Posted on Jul 05, 2010
Is there a way to manually drain reservior tank, put soap in and tryiing to remove soap
Hi James:
I'm guessing you're asking about the windshield washer reservoir.
I'd top it up with water, then use a piece of hose to siphon it out. Repeating the process a few times should clean it out quite adequately and it's a lot faster than trying to use the washer pump.
To avoid sucking on a soapy water hose, just fill it with water and block the ends, stuff one into the reservoir, and hold the other close to the ground, then release the end.
Cheerfuls.
Jul 12, 2016 | Cars & Trucks
How change robertshaw 110-32f
Turn off gas to the heater close water supply drain the water out of heater.Remove pilot tube assembly remove thermocouple/or thermopile assembly disconnect gas at the union and remove from valve. Use wrench that fits the hex shaped nut that holds the aquastat and water heater in the tapping. Usually the wrench size is 3/4" or 7/8" depending on the unit.
Put pipe dope on the male thread of the valve and keep it off the aquastat bulb, and rethread into the tapping.
Replace the ilot assembly being sure it was not damaged when it was remover if it was damaged replace it. replace the thermocouple/powerpile assembly replace the gas piping from the valve being sure to use pipe dope on the fittings and tighten them enough so they do not leak. Do not use teflon tape because it could get into the gas valve and cause problems.Test the gas piping for leaking do a tight test on the meter if possible or test with testing fluid and look for bubbles or use a gas leak detector that sniffs for gas and beeps when it detects a leak
Fill the water heater up with cold water and check to be sure there are no leaks at the thread where the valve is threaded into the tapping. Open a hot water faucet and be sure the heater is full of water.
Light the pilot and turn the gas on set to the temp that is best suited to you..
Apr 06, 2014 | Robertshaw 110-32F/110-326 Natural Gas...
Run out of gas and put some watery gas in the tank, it cut off 3mins later
Just plain silly. Remove gas tank, drain and dry. Replace fuel filter. Fill gas tank with 5 gallons of fresh gas. Add a bottle of water remover to tank then start and drive. Good luck.
Aug 21, 2013 | Toyota Cars & Trucks
Coffee holder cup blocked
The same just happened to me, thus, looking for a replacement filterholder.
Jun 12, 2013 | Ariete Cafe Retro Espresso Machine
Bosch 22e ys2439r fault 14 , (pcb 1 long flash and 4 short flashes ) cannot get unit to work , i've tryied replacing the pcb,gas valve w. solinoids ,thermistors...etc the fan will kick in for a second but...
No I cannot help fix your tankless.
There are just too many things that affect the operation to offer clear solution.
Before calling service technician, open following link for Bosch troubleshooting resources, including contact information for Bosch.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Repair most tankless water heater problems yourself, same day, any brand, for $320
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help, and to share your tankless solution.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 02, 2011 | Bosch Water Heaters
It has stopped working; I can see the cursor on the screen but there's no response. I have rebooted, but it has made no difference.
I have the same problem. It worked fine for over 7 years now. Yesterday I put it into the charging device after I switched off the Mouse. Started to charge. In the moring I took it off and slide the Off button to On. The battery indicator shows full. Windows 7 recognize it but no mouse movement. I tryied 2 different computers (both with XP) and the mouse is recognized but not working. I tryied to look into the laser lens but no red light there.... I also tryied to put it into charghing the Red Status Lid for 1 second and after it goes all green.
What to do???
Oct 25, 2010 | Logitech MX1000 Laser Cordless...
Had water in the fuel filter replaced it and now it tries to die if I'm at a red light
add two cans of Heat gas treatment to it with a full tank of gas to eliminate the moister that is left in the fuel system
Jun 27, 2010 | 1999 Buick Regal
My car is leaking coolant and i cant tell from where. I tryied replaceing the cap and that didnt help
The list is large of WHERE it could be, we could guess all day. Fill it with water and see if you can find out where. Heater hose? Radiator hose? radiator? water pump? freeze plug? Heater core?
May 12, 2010 | 1993 Ford Taurus
Nokia 6080 Fell in water
It is stuffed, if it falls into water then the second it falls in it will short, and probably blow some critical components inside, even if the phone is off then there is always power running through it (so it knows when you are pressing the button to turn it on, also so it can remember the time and date)
May 24, 2009 | Nokia 6080 Cellular Phone
1999 Firebird cranking problem
well first the white smoke indicateds water in fuel system. if you have a strong fuel smell that would indicated that your getting way too much fuel. there are several reasons for this. it could be that the fuel pressure regulater is malfunctiong. the throttle position sensor is bad. it could also be a timing issue.
Aug 28, 2008 | 1999 Pontiac Firebird
Poulan "" Push Mower Logo
142 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
