Question about Fuji FinePix S7000 Digital Camera
What does card protected mean when you place sd card in camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
SD (and SDHC) cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Jul 05, 2010
What does it mean protected card?
You didn't specify the model of your Fujifilm camera so I'm assuming it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 16, 2014 | Fuji Cameras
What does write protected mean?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 03, 2014 | Nikon Coolpix S6100 Digital Camera
What does write protect mean after inserting sd card?
Jan 20, 2014 | Olympus Sp-800uz 14mp With 30x Camera...
My camera says card protected when i turn it on what does this mean?
You didn't specify the make and model camera, but I assume it uses SD and/or SD cards. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 09, 2010 | Cameras
What does 'Write Protect' mean and how do I get rid of it?
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
Apr 09, 2010 | General Electric A735 Digital Camera
When i put the memory card in it says card locked. what should i do?
Check the position of the "write protect" or "lock" tab on the SD card. Make sure it is (and remains) in the "unlocked" position when inserting into the camera. Some cards have flimsy lock tabs that do not require much effort to reposition. If you are not careful, the tab may be moved during the insertion & ejection process. You can ensure that the tab stays in place by putting a small amount of scotch tape - or a drop of super glue to hold it in place. Of course, if you go the glue method, it will be permanent.
Lastly, this camera supports SD cards up to 4 GB in capacity. That is, a 4 GB SD card - it does not mean a 4 GB SDHC card or any card greater than 4 GB. Make sure you've got the right card inserted.
I hope this helps!
Oct 22, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
SD card Protected
It sounds like the tiny locking switch on the SD card has accidently been set to "lock". Remove the card from the camera and slide the switch to the opposite position. That should do it.
Apr 25, 2009 | Fuji FinePix Z10fd Digital Camera
Cant take picture. polaroid a500 camera reads sd protected.
It means the sd card cant be accessed unless you remove the protection . Connect sd to laptop and use software to remove the protection .
Mar 13, 2009 | Polaroid A500 Digital Camera
Card protection on wii not take pictures
I assume you mean the card protection on the SD card??? Turn off the camera, pop out the SD card, slide the little switch on the side of the SD card from locked to unlocked, re-insert the card the way it came out, and turn the camera back on. If it still doesn't work, take thed batteries out, reinsert them, then turn it on again. It should be ready now to record onto the external memory. If it still doesn't, get the manual out and check on transferring fiels from internal to external memory.
Feb 27, 2009 | Polaroid T730 Digital Camera
Micro sd card says write protect when inserted what does that mean
Hi , means you connot delete the picture , the only remedy to erase the write protect to format the micro sd , for the next time dont click to write protect .
Mar 03, 2008 | GE E1040 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
134 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
