Question about Panasonic Viera TH-42PX80U Plasma TV
Hear the tv but no picture
The tv screen is black, but you can hear the background noice perfectly
  • 979 Answers
Hello nea, hi there are several possibilities, one most common solution is to find loose contacts and loose screws that need to be tighten, and the other is caused by a hardware failure, this is usually the back light, if your TV is the LCD type check for the inverter circuit that powers the back light, If the TV is LED type, check for warranty, LED is still new, so I guess the TV is on warranty, if not the circuit that powers the LED need to be checked, all of this needs the TV be disassembled, if not check out first your dealer for service.
Posted on Jul 05, 2010
I have a 60" Samsung led TV. Model number UN60EH6003F/type UN60EH6003. The TV turns on but doesn't show a picture. You can see the screen light up but stays a black background. Which board is bad?
well 1st before id go changing any parts I look at weather or not the input is selected correctly over to the input that im providing a known good picture signal with (antenna,cablebox,etc.), you'd be surprised how many times I get a call and I go and use the input select buttons on set itself (NOT REMOTE) and whhoolaaaa! there it is , of course I always hear next I didn't change that !!
a short comings of todays modern TV's if you arnt having any signal into it ,the screen is black and the set-up menu wont display on a black screen
Oct 27, 2015 | Samsung Televison & Video
Background noice on tv is too load, can't hear voice.
Look carefully in Menu---many Toshiba sets have a HALL or Theater setting which will make background louder than people talking--likely your problem and the owner manual should explain this.
Apr 20, 2012 | Toshiba Televison & Video
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
We bought a new fan for our xbox 360 on sunday and yesterday while playing Modern Warfare, the screen went completely black. We tried different tv's, but the screen stays black. We can hear noise like...
possibly unrelated. try testing the connections to the tv and the x-box. if thats solid then try removing the fan unit to see if it is the culprit.
Dec 02, 2009 | Microsoft Xbox 360 Console
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Philips Magnavox 36" @10yr old has perfect sound and black screen
checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Jul 31, 2009 | Philips Magnavox TS3260C 32" TV
Can't see regular TV but can hear it
replace the vertical output IC that should take care of it.
Feb 02, 2009 | Sony KP-61V90 61" Rear Projection...
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Have power but no sound or picture
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
Jul 02, 2008 | Philips 50P8341 50" Rear Projection...
Display images missing on MP3, background black!
You can set one of your own pictures as the background by viewing it and holding down the center touch pad button. The bottom of the screen will say Set Wallpaper and you can let go of the button. now that picture will be set as your background image
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Panasonic Viera TH-42PX80U Plasma TV Logo
135 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
