Question about McCulloch FH140A Electric Pressure Washer
No pressure with detergent bottle on
How do I attach detergent bottle to have pressure
    Master:
  • 502 Answers
You wont get pressure with detergent bottle on.it only sprays low pressure .just take off first section of wand,and plug it in
Posted on Jul 05, 2010
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
Where does the detergent bottle go
It goes onto the wand itself. With the Pressure Washer off: If you have the wand unattached from the hose it works easier. Then separate the WAND into two pieces at the big joint in the center. Insert the bottle into the joint on the opposite end of the section that will be attached to the hose, (once you have the wand in two pieces you will see the same types of connections that are on the bottle.) then attach the other end of the wand to the bottle. Now reattach the wand to the hose.
Dec 03, 2014 | Campbell Hausfeld PW1750 Electric Pressure...
How to repair non-functioning detergent bottle
Are you really sure it's not working? Most of these only dispense detergent when the lowest pressure spray head is attached. If that's not the problem then the next most likely thing to check for is a blockage in the tubing that connects your detergent bottle to the main unit. If this was not fully rinsed out after the last time it was used, any residual detergent remaining in the line will often solidify which results in blocking the line. Good luck
Nov 10, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
Cannot attach wand after attaching the detergent holder
put the detergent holder on the end of the wand handle.take off the first section,and put bottle into that hole.my Nilfisk waterblaster is the same
Jul 05, 2010 | McCulloch FH140A Electric Pressure Washer
I have a detergent tank and cant seem to get detergent to come out what do I need to do?
Dear bug4222,
I have never worked on your type of machine. But generally this is what you do. Disconect the pipe from the inlet to the machine. Attach another pipe and put the other end in a bottle of water. Start machine and on low pressure see if the machine sucks water from the bottle. If this does not happen, try to service the inlet part at the machine. This usually it will have a ball-bearing as a non-return valve. This non-return valve sometimes gets stuck. If you see that you have solved the fault in the non-return valve, attach the detergent tank as it was, but instead of detergent, use water. You should always use low pressure. If all is OK, try some detergent. Always remember that after using detergent, always pass clear water from the detergent tank. If you leave detergent in the system, this will cause problems.
Regards,
Fultech.
Jul 16, 2009 | Campbell Hausfeld Garden
My TroyBilt Pressure Washer 2500 PSI 2.3 max gpm will not pull detergent through the tube. I have the correct tip on the nozzle and the tube connected to the pressure washer and in the bottle of detergent...
if you follow the chemical hose back to the pump it will be attached to a barbed nipple, behind the nipple there should be an o-ring, spring and a ball.
A lot of the time if you are using the proper nozzle in the low pressure setting and still cannot create suction the ball will be stuck to the o-ring. You can just free this up and put a little white grease on the o-ring.
Troy
Jul 08, 2009 | Briggs & Stratton Garden
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
McCulloch FH140A Electric Pressure Washer Logo
216 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
