Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Icemaker not making ice.
My icemaker was just re-hooked up but it is not making ice. Help!
    President:
  • 1,218 Answers
First, it's important to know that the freezer must be at normal temperature. Any temperature above 15 degrees will cause the ice maker to lock out automatically.
Assuming it is normal, then follow these steps to get it up and running.
Check to make sure it is in the on position and check the water supply at the valve (covered in the steps below)
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jul 05, 2010
No icemaker but makes a noise like when water is drawn to make ice
If the icemaker is still in the freezer, be sure it is turned off (usually OFF is the metal feeler arm locked in the 'up' position) because the unit will still call for water even if the water line is not hooked up...
May 24, 2016 | Kenmore Refrigerators
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Ice maker not hooked up (on purpose). The ice
Sounds like you are not going to use the automatic icemaker, so I would remove the whole icemaker unit which will include disconnecting the wire harness behind the icemaker which will shut off power to the icemaker and will also give you more storage room in your freezer compartment.This will not harm the refrigerator or the icemaker, you could also disconnect the waterline if you want.Please note that this solution applies to the top freezer,and bottom freezer style refrigerators only thatt DO NOT have dispensers through the door. Good luck !
Dec 02, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
I want to install my icemaker it is not working
Pour some water into the icemaker and wait for a sign of ice production. If it makes a batch then fails to produce anymore then check that water valve. If it does tose out any ice at all then check that ice makers connection or get another. Give that puppy 24 hours to start making ice. Read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
My ice maker isn't making ice
the way the ice maker sits in the front of the freezer I personally think is not a good design.nice but not good.most every k.a. superba that had problem with icemaker that i have checked had a bad ice maker.replace the icemaker.but you may want to check all tubing connections from water valve to icemaker and make sure no break in line.most likely it is the ice maker.that ice maker is not a cheep one.good luck.
Mar 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not turned on or hooked to water line
it my be not the icemaker check fan or you can remove icemaker
Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
475 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
