My hotpoint aqualtis washing machine doesn't finish a wash cycle it flashes up F-05
    Champion:
  • 274 Answers
Push the start button again and restart your pump has a slow clog.it may take a while to drain.after you have the clothes out run 2xclorox through it.
Posted on Jul 05, 2010
Hotpoint aqualtis AQXXL 129PI
could be a bad timer? sticking at the wash cycle. it does agitate right? other wise bad water pressure switch
Aug 07, 2014 | Hotpoint Washing Machines
Hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
find a dealer and get a manual for the washer it will have a trouble shooting section will tell exactly what is wrong
May 17, 2014 | Washing Machines
Hotpoint aqualtis washing machine model AQXXL 129 PM , runs through the cycle then stops at times leaving water in the drum and all lights flash why ?
the pump could possibly be jammed. you will need to drain the machine and remove the filter to check for any obstruction
May 17, 2014 | Hotpoint Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
My Hotpoint Aqualtis AQXXD 169 PM is adding time to the was cycle, taking longer to wash through the cycle? ant ideas?
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
Nov 11, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Aug 03, 2008 | Washing Machines
My Hotpoint Aqualtis washing machine keeps getting stuck towards the end of its cycle. It shows a F-05 on the digital display. Previously I was able to get the washing machine to finish by putting it on...
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Jul 08, 2008 | Washing Machines
Washing Machines Logo
535 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
