Question about Husqvarna 20HP Hydrostatic 42" Cut Riding Mower
Reverse will not function backing up a hill.
Reverse will work on level surface, but at a much slower speed than forward. Reverse will not pull weight of operator backing up a hill.
this is a 42" 20h.p. Kohler hydrostatic tractor. Has not operated backing up a hill since new.
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
  • 4 Answers
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
Posted on Sep 16, 2009
  • 4 Answers
SOURCE: Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Posted on Sep 17, 2009
wireguy212
  • 1627 Answers
SOURCE: After a couple passes tractor will not climb hill.
To me it sounds like the hydro unit has developed internal leaks and the pressure lowers as the oil thins from heat.These trans axles are usually replaced as an unit but some can actually be repaired.call the dealer to see if you can get parts or whether you need to replace the whole thing.I assume you have already tried a new drive belt,tensioner ect. and if so you are down to the trans axle.You may buy some time buy getting rid of the low viscosity oil in the rear end and go to regular hydraulic oil.
Posted on Dec 23, 2009
agent91
  • 2100 Answers
SOURCE: Where should I drill a fill hole for my MTD made
Why do you have to drill? No plug? Check out the back of that thing, the plug might be on the side, the back, the front, not necessarily on the top. The fill plug will be the level too, fill it up till it seeps out. Then plug it up. Hope this helps.
Posted on Jun 03, 2010
Why does't my allison AT545 go into reverse?
Disconnect the battery . Take off the plugs on the trans and clean the connectors with electrical cleaner spray ck all the wires to make sure none are broken , put plugs back on , how long has this been going on could be bad reverse clutches r u pulling a lot of trailer weight around and backing up with it and lugging it ,it is not a tank if so ,
May 16, 2014 | 2005 Gmc Sierra 2500 Hd Allison Automatic...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Timecutter 4235 pulls to the right
first check the air pressure in the tires make sure they are the same then move the linkage rods on the slower side to balance the speeds out if it doesn't balance out you might have a pump or drive motor failing each side has its own pump and drive motor assuming you already check the fluid level
Aug 11, 2012 | Toro Lawn Mower With Toro Power Tools
Zero Turn mower no power in forward - power fine in reverse
yes check for play in linkage bushings the look for a adjustable rod
May 28, 2012 | Garden
2005 Kia Sorento - in 4 wheel drive, on dry pavement, going slow in forward, turning a corner to the left the rear drivers side wheel tries going in reverse and when turning right the passenger side wheel...
Yes, this is normal while in four wheel drive on pavement.
I will try and explain why.
In four wheel drive the front and rear drive axles are linked together by a chain in the transfer case and gears in both axles. This is a direct link with very little play between the front and rear axles.
When cornering a rear wheel will spin faster, or slower depending on the direction of the turn. this causes a binding in the drive line because the drive line wants all the wheels to turn at the same speed. So the wheel "skipping" going in reverse, is the drive lines way of compensating for the different speed of the wheels turning.
Never should a four wheel drive be used on dry pavement. I could cause a break in one of the drive line components. On a slippery surface , snow, mud, gravel, grass, There is enough slippage in the surface to aloow the driveline to compensate for the different speeds of tire rotation.
So do not try at highway speeds on dry pavement.
Your four wheel drive system is working just fine.
Wayne
Jun 21, 2011 | 2005 Kia Sorento
Hi.The mower works fine except it gets very slow and will completely stop moving when reversing up a slope. It is slightly slower in forward as well. The petrol engine is running properly, and all the...
Perhaps you are low on gas and because your tank is tilted as you wheel backwards up hill, the gas line is not getting what little gas is in the tank.
Jan 14, 2011 | Garden
Cruise control will not maitain the speed it is set on. going up a hill it gets slower and going down a hill it gets faster
My experience is that cruise control works on level roads, uphill you have to control speed yourself same for downhill. Exception is very powerful cars. Did it maintain speeds before? (uphill + downhill)
Mar 08, 2010 | 1994 Buick Park Avenue
For an Embassy shredder, the forward function is not working.
I was able to figure out the solution for this by taking apart the shredder.
My model is a TX61B. There is a piece of plastic that is attached to an internal sensor. You can see it below the shredder slot with a flashlight. if it is sticking out, the sensor is not tripped, and the forward function stops.
To reactivate this, just put something down the slot like a thin screwdriver to push the plastic lever back, reactivating the forward function.
I could see this being caused by running too much paper in reverse mode, which I recently did.
Aug 12, 2009 | Office Equipment & Supplies
2002 jetta TDI- I try to accelerate up a hill and no power
Count the shifts. It sounds like you are going into overdrive and staying there. Overdrive is too long legged to pull most hills unless you are really flying.. good luck
Jul 12, 2009 | 2002 Volkswagen Jetta TDI
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
215 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
