Question about Maytag PAV2300 Top Load Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks ago, it started making intermittent screeching sounds during spin cycle...then those sounds stopped a couple of weeks ago. Now it's stopped spinning. Any idea what's wrong? We can handle small repairs, but don't feel comfortable taking apart the washer. Our options are: doing it ourselves if a minor repair, calling a repair person, or junking it and buying a new washer. Any recommendations/advice would be greatly appreciated!!
    Champion:
  • 274 Answers
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Posted on Jul 05, 2010
Testimonial: "Response was helpful to figure out our options!"
  • brandon_1987 Nov 07, 2010
    Its not the clutch. its the Thrust bearing.......comes in a kit for cheap..30 bucks shipping included and is a easy fix - Transmission pulley and bearing kit. This kit includes pulley, washer, thrust bearing, 2 upper race washers, 1 lower race washer, and instruction sheet.
    its not time for a new washer..its time to fix it and listen to someone who has had this problem b4 with the same make and model washer.....i bought mine on craigslist for 10 bucks and fixed it for 30 and sold it for 200.00
    Read more:http://www.appliancepartspros.com/part_d... http://www.appliancepartspros.com
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Maytag pavt244aww
We had the same problem and it is a known problem by Maytag. They came and replaced the springs under the drum as the original ones were not stong enough.
Dec 10, 2009 | Maytag Washing Machines
I have a maytag washer model# pavt244aww and it jumps all over the place while it is spinning. any ideas what the problem could be I cant seem to figure it out
There is a stabilizer bar that stretches across the back of the washer, and a pivot point in the right front corner. Both can be accessed through the back panel (tension bar) or top (pivot) of the washer.Look for one end of the tension bar having become disconnected, or the pivot point having become dislodged or broken.
Seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Oct 27, 2009 | Washing Machines
Maytag washer model PAVT244AWW will not agitate during wash cycl
When the machine drains etc the gearbox locks up and the whole unit drum box and all spins when washing the gearbox innerds move the otherway so to speak and this cuasees a washing action this sounds as if the input shaft may need replaceing but it is usually better to replace the gearbox depends on finances but to be sure get a technition in to check and quote you first this is not something you can do if you have not done it before
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag top load washer pavt244aww leaking into drain
Chad -- Your problem most likely is the drain hose is either
a) Clamped tight to a drain line of some sort allowing water to siphon out
b) Washer drain hose is Shoved too far down the drain pipe
c) Drain pipe is lower than tub of washer alllowing water to drain
Oct 18, 2007 | Washing Machines
MAYTAG TOP LOAD WASHER
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Jul 03, 2007 | Maytag Atlantis MAV7260B Top Load Washer
Maytag PAV2300 Top Load Washer Logo
1,265 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
