Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
I have a Kenmore model 50522100 and need to know what water filter to replace with
huuum
  • 750 Answers
SOURCE: How often do I change the water filter
Hello welcome,
here is the site to get and or print out your manual for your Kenmore Coldspot, Model # 106.74962400
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406138.pdf
Thank you , Huum
Please leave a solved rating before you sign off!
Posted on Dec 07, 2008
mark_37388
  • 100 Answers
SOURCE: Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Posted on Apr 02, 2009
  • 103 Answers
SOURCE: Kenmore 106 50522 water leak from Icemaker
Hi: Usually if the ice maker malfunctions that bad it will keep running and flood bad. If your defrost drain is plugged it will puddle water. Without knowing how much water you see it is tough for me to say precisely. Does the ice bin have a big block of solid ice or cubes? If cubes I would guess it is the defrost drain at the bottom of the fridge. If the drain is clogged the water wont get to the pan to evaporate. If the defrost water has nowhere to go it will puddle. This would produce more water on the floor in a humid area than a desert like I live in. If so look at the bottom of the freezer in the back below the metal panel. Usually there are slots above it. There will be a hole at the bottom of a shallow rectangular funnel. Turn off the fridge and put your food in a cooler. Pour some warm clorox water in the hole, a fairly strong solution. It should eat out the mold that grows in the base of this non refrigerated line. If something like a frozen pea got in the line you might have to use a pipe cleaner to snake it out. Good luck with this, Jeff
Posted on Jun 01, 2009
SOURCE: I need help replacing a Kenmore Elite Water Filter - 46- 9010
insert it so it is vertical and then rotate one quarter turn to the right so it is now horizontal nad the line matches the grill on the front of the fridge.
Posted on Jan 27, 2010
  • 97 Answers
SOURCE: Need to replace the water filter in someones
Mine is on the outside of the refrigerator below the door on the right side. It is round with a middle handle to unscrew it. Best of Luck
Posted on Mar 10, 2010
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
I need a replacement filter for my kenmore coffee maker item#69768
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
I need to know which is the Serial or part number of the Water filter of the Kenmore Refrigerator Mod 106.58953800 I need to replace it and get a great price Where?
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/9030/0046/046/Model-10658953800/0582/0165000?keySuffixId=&productTypeId=&searchModelNumber=10658953800&blt=06&subCompDesc=CABINET%20PARTS
Sep 05, 2010 | Kenmore Refrigerator Replacement Water...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
How do I know when the filter needs changed
water filters are usually see through, if you see dark brown, it should be replaced, if its been a couple of yrs
it should probably be replaced
Oct 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
May 31, 2009 | Kenmore 50522 / 50524 Side by Side...
i cant even find a filter on your machine, if there is one, there will be a model number on the filter itself as well as re-order information.Once a yr , you shhould change
Dec 07, 2008 | Refrigerators
Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Oct 11, 2008 | Kenmore 53642 / 53644 Side by Side...
How to remove ice/water panel on the outside of the freezer door
Your model number appears to be the same as mine. If you gently pull off the panel marked with the ice/water by placing your fingernails just behind it and pull toward you the plastic panel should come right off. Behind that are the four screws holding the circuit board support to the fridge frame. All I did was pull the four screws, gently removed the wiring harnesses, tilt the plastic holder toward me and remove the two circuit board retainer screws to replace the board. Reversed the process of putting it all together and it worked like a champ.
I hope this helps.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
207 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
