I was able to burn a couple of dvd-r's on my macbook with some new software by Roxio - Toast. On the third or fourth dvd (all were from a brand new sealed pack of dvd-r's), there was some kind of error. I put another disc in and it said "please insert blank disc." I tried several other discs, tried restarting the program, restarting the computer .. Idk what to do! Please help!!
    President:
  • 4,070 Answers
Hi! If restarting the pc doesnt help on the cd burning then you have a bad blank cdr. Eventhough the cdrs are sealed you can not really tell if there are bad ones. Try opening a different pack and see how it goes. If still fails, try burning the cd on other pc. If it works then the optical lens of the mac cd burner is faulty. YOu will need to run a cd lens cleaner to fix it. Hope this helps and have a good one!
Posted on Jul 08, 2010
    President:
  • 1,561 Answers
There are few things you need to work on this kind of situation, first is that, i advice you uninstall the roxio-toast software and reinstall back on your system, because it is possible that it is corrupt that is why it is given such error, uninstall and reinstall back the roxio software.
If the problem still persist after this, the problem could be that the lens could not read the disc any longer, maybe, the lens on your system is weak that it can no longer read disc, if so, replace the lens on the dvd ROM. lastly, i would suggest you reinstall the operating system by carrying out repair on the operating system because the operating system might also be corrupt, that is why it is given such error.
But the most important is uninstalling the roxio software and reinstalling back because it is possible it is corrupt, but if the problem persist after carrying out this, then the dvd ROM is the problem and might need to be replace.
Take care.
Posted on Jul 05, 2010
  • 2 more comments
  • beftodef Jul 05, 2010
    Well, even when Roxio is not in use, and I insert a blank dvd ... It ejects it after a few seconds. SO I think it is a problem with the dvd-rom. Could that still mean it is the lens?
  • Sulaimon Jimoh Olayemi Jul 05, 2010
    The problem is not the lens since it dvd ROM rejcts the cds, if it lens problem, the lens will only not read the disc, that is the work of lens, just to read the disc, but in this case, if you have the dvd rom drivers, uninstall the present one on the system and reinstall the dvd rom drivers, but if problem still persist, then it means the dvd rom will need to be replace.
    Take care.
    Okk .. That was the enxt thing I was gonna try. Do you know how I can do this on a macbook?
  • Sulaimon Jimoh Olayemi Jul 08, 2010
    Procedure on how to replace the dvd rom on your macbook
    Rub one of the short edges of the credit card against the sandpaper.
    Stop rubbing when the short side develops a beveled edge.
    Put a soft cloth down on a table. Close the lid of the MacBook. Put the
    MacBook face down on the soft cloth. Insert a coin in the battery slot
    and twist the slot. Pull the battery up and out of the MacBook. Touch
    the inside metal of the battery compartment to remove static
    electricity.
    Use the Phillips jewelry screwdriver to loosen the three screws at the
    edge of the battery compartment. Lift out the "L" bracket from the
    battery compartment, starting from the right side. Turn the MacBook back
    right side up.
    Use the Phillips jewelry screwdriver to remove the two screws from the
    front of the MacBook next to the ROM drive's disc slot. Use the
    Phillips jewelry screwdriver to remove the four screws from the back of
    the MacBook. Turn the MacBook over and remove the three screws from the
    bottom using the Phillips jewelry screwdriver.
    Use the Phillips jewelry screwdriver to remove all of the screws from
    inside of the battery compartment. Turn the MacBook back right side up.
    Insert the beveled edge of the credit card between the top case and the
    left side of the MacBook. Move the credit card down the length of the
    MacBook. Lift the top case up off the bottom case from the front.
    Disconnect the ribbon cable at the front from the bottom case with the
    flat-edged screwdriver.Pry the Bluetooth antenna up off the upper right corner of the bottom
    case with the flat-edged screwdriver. Use the Phillips jewelry
    screwdriver to remove the screw next to the antenna that is at the lower
    left of the MacBook's ROM drive. Use your finger to disconnect the
    copper colored cable from the ROM drive. Peel the plastic tape off of
    the copper colored cable.Move the silver cable aside and slide the bracket away from the ROM
    drive with your finger. Grab the tab at the edge of the hard drive that is next to the ROM drive and pull it out from the bottom case. Use
    the Phillips jewelry screwdriver to remove the two screws from the ROM
    drive that were hidden by the hard drive.
    Lift up the cable running alongside the ROM drive. Lift the ROM drive up
    slightly and push the cable beneath it. Use the utility knife to cut
    off the antenna holder on the ROM drive. Carefully pull the metal
    bracket from off the ROM drive.
    Remove the tape from the back of the ROM drive. Pull the cable from out
    of the connector in the back of the ROM drive. Remove the ROM drive and
    discard it.Attach the metal bracket to the replacement ROM drive.
    Attach the
    cable to the back of the replacement ROM drive. Attach the tape to the
    back of the replacement ROM drive. Reattach the replacement ROM drive to
    the bottom case of the MacBook.
    Reattach the hard drive to the MacBook. Reassemble the MacBook. Reinsert
    the battery into the battery compartment. Put the MacBook face up on
    the soft cloth. Raise the MacBook's lid and turn it on. Use the MacBook
    with the ROM drive that you have changed for the one that it had
    previously.
    Take care.
    Genius:
  • 1,354 Answers
Hi
try to remove your DVD case the refix hope fully it will work
some time motherboard wano't tak propely conection
  • 6,993 Answers
check the DVD plates you successfully burnt, with the ones that refuse to be recognized by the Macbook, make sure they are exactly the same brand/make and type. Because there are some empty discs that are + while some are -, so check if there is any difference between the dvds that you burnt with the ones that did not burn.
If the dvd's are exactly the same, then maybe your macbook burner has over worked and needs some rest, that's why its not recognizing other empty dvds.
So, shut down the macbook and allow it cool for couple of hours, then you can continue burning thereafter. I believe it should respond well by then.
Good luck.
    I checked the cd's and turned my computer off for a while ... still no luck. :(
This is a video that I made and want to copy. Toast will make a disc image, it puts the picture of the 2 clips, and then says "could not record the disc because a file could not be found" Result code
Your burner program wants to make an image so the video can be played in a DVD player. If the format is not correct it don't want to burn the disk. Please read the manual from the burner program, or press the F1 key before you start. I hope they inserted some help in the program.
Jan 13, 2015 | Roxio new toast 7 titanium/en cd mac roxio
Tip
How to Rip & Burn DVDs on a Mac
1) Download and install Handbrake. This free software allows you to easily rip DVDs on any Mac with OS 10.3.9 or higher. Download and install Roxio Toast to compress and burn the DVD,
2) Insert the DVD that you want to rip into the DVD drive. Close any DVD program that starts automatically. Open Handbrake.
3) Make sure that the "Detect Volume" option is selected and click the "Open" button. The Handbrake software will scan the DVD, collect all pertinent information and open the main menu.
4) Make sure that the title Handbrake selected for the DVD is correct. If it is not correct choose the appropriate one from the "Title" menu. Choose a destination for your ripped DVD in the "Destination" section of the menu, the default being your desktop.
5) Click the "Rip" button. (Do not interrupt the process or turn off your computer until the DVD is ripped.) This will create the ripped files and a folder structure which includes a "VIDEO_TS" folder.
6) Open Roxio Toast and select the "Video" tab. Select the "DVD-Video" option from the "VIDEO-TS" menu. Select the "Fit to DVD Compression" option to burn the ripped files onto a single-layer DVD.
7) Choose the "VIDEO_TS" folder that you just created by clicking on the "Select" button. Choose which options you want for your ripped DVD with the "Copy Options" button.
8) Insert a blank DVD into your DVD-R drive. Click the red "Burn" button in Roxio Toaster and allow the program to run its full course. Now your DVD is ready to watch on any DVD player.
Hope this helps.
on Sep 10, 2010 | Computers & Internet
Whenever i burn a dvd with Roxio "Easy" CD &
The service packs are trying to stop pirating software.
Not very good software. TRY Nero Express and Power DVD
http://www.nero.com/eng/downloads-nero10-trial.php
Feb 10, 2011 | Roxio Easy CD & DVD Burning
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Record to dvd downloaded movies
Get the program "Toast" by roxio software.
in my opinion its the greatest burning tool for the mac. It does dvds and cd for music, data and video and stuff.
Jan 20, 2009 | Apple PowerBook G4 Mac Notebook
Trying to copy a DVD
Sometimes different DVD software and DVD writers are picky with the type of DVDs that you put in. Try a different brand and see if that makes a difference.
Nov 26, 2008 | Roxio Easy CD & DVD Burning
dear custumer
the Roxio Easy that u are loading on your windows is a new version
so why it can not run on an old version on windows like yours
so try to replace your windows 2000 by the new version of it .
Oct 31, 2008 | Roxio Easy CD & DVD Burning
LaCie DVD Burner Not Doing Much of Anything
You should check for corruption of your CD/DVD burning software from whereever you got it. Sometimes some burning software isn't good enough to work adequately. I'd test some new burning software to see if that is the problem, if upbrading your burning software doesn;t do the trick. You can downlowad free trials of Roxio, NTI, and other good burners to test this hypothesis. And, of course, try calling LaCie support.
Mar 06, 2008 | LaCie 16X LIGHTSCRIBE DL d2 DVDRW USB2&FW...
Installing toast 8 application
did u get the software secondhand? if so maybe it's already registered to someone else.... if not you would be best contacting the company directly for assistance.
ROXIO Support - http://www.roxio.com/eng/support/default.html
Dec 17, 2007 | LaCie d2 DVD-RW Burner
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
