Question about Kenmore HE2 Plus Front Load Washer
Door will not open & elctronic panel won't work
Electronic panel won't work and door will not open. Have service call in but want to get the wet laundry out. Is there an emergency trigger to open the door?
Same thing happened to mine spent $120.00 on ccu no click then checked continuity with digital multimeter on ac line filter no reading so I replaced this , well what do you know damn thing now works. Sears just wants to waste your valuable time and money with repair people for this small problem. Unplug unit first Take the bottom panel off 3 screws underneath 1/4 inch socket, once you take the panel off reach up on the side where the latch is you will feel a ring, pull that till you hear the door release.
Now as far as no power to panel there are two solutions one is to plug unit in listen for a light click to see if ccu is getting power if there is a click then ccu is good if no click unplug test your ac line interference filter if there is no reading replace your line interference filter the one going to the power cord.
Posted on Jul 07, 2010
    Genius:
  • 1,075 Answers
No.door switch is gone,when it malfunctions the power board stops working.there is a way but it involves a bit of knowhow and time.adrian,,,
Posted on Jul 05, 2010
Door won't open
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Details about this fault has been described here.
May 15, 2012 | Televison & Video
Door won't open
May 15, 2012 | Panasonic DMR-ES10 DVD Recorder
The door lock won't open. I unplugged unit to reset, but still can't open door.
try finding the manual release..on my bosch nexxt 300 there is an access panel on front lower right of unit for the drain if i open it and reach up there is a cable to pull on to manually unluck the door...have wet vac ready as there might be water from a clogged drain causeing washer to keep door locked
Oct 10, 2011 | Frigidaire ATF6000ES Front Load Washer
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
E:13 Error on our Bosch 500. I threw a load of wet towels (from swimming) and turned it on. About a 1/2 hour later I heard it beeping, so I went to check on it. The soap was still in it, which tells me the...
Hello & Welcome to FixYa
E13 error in your Bosch washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Washing Machines
My 1996 blazer has a dead battery and the electronic door locks won't work. How do i get in to my blazer to open my hood?
use the key drivers side still has a key[manual open ] hole if u dont have a key will to slim jim the door call a service station or lock smith
Jul 07, 2011 | 1996 Chevrolet Blazer
Door has worked fine for years with a Schalge camelot electronic lock. Tonight it stopped working and you could not open the door with the inside or the outside handle. Key would not open door either. I...
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Apr 16, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
How do i put my eectronic flsher in my car
I would suggest that the flasher is either in the fuse box, or in the electronic distribition box (black box near the front driver's side) in the engine compartment under the hood. Unplug old one and install new one with comparable replacement.
Apr 01, 2010 | 1999 Ford Taurus
2007 chevy equinox turn signals, hazard lights, lift gate stopped
i have the same problem with my 2007 chevy equinox. how can i fix it?
Nov 16, 2008 | 2007 Chevrolet Equinox LS New Cars
Kenmore HE2 Plus Front Load Washer Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
