Question about Brother MFC 4820c All-In-One InkJet Printer
Brother fax machine mfc #4828c
The black ink is very light. I Can barley see it. can you help me with this problem ? I have already changed it a couple of times.
    Sergeant:
  • 202 Answers
Hello marand
(A) Did you mean the Brother 4820C MFC? (I could find no listing of any 4828C Brother device on any of Brother's regional sites)
(B) If that is the case, you can find documentation for this MFC HERE.
(C) Select:
Multi-Function Center in the top box
(D) Select:
MFC-4820C in the box below that.
The result will be links to your machine's Users Manual and Quick Setup Guide (in English)
The suggestions below are referencing THIS User Guide.
(E) Please, refer to section 23 of the Users' Guide "Troubleshooting and routine maintenance"
(F) Click the [+] sign to the left of the number 23
(G) Click the [+] sign to the left of "Troubleshooting"
(H) Click on "If you are having difficulty with you MFC"
(I) Refer to the 4th item listed "Printing is too dark or too light".
(J) Follow the recommendations there and make any necessary changes to your cartridges or paper.
If the issue persists,...:
(K) Click the [+] sign to the left of "How to improve print quality"
(L) Follow the instructions in this section on "Cleaning the print head" and "Print Quality Check"
(M) If you are still experiencing the same issue, review section 23 entirely and see if any other issues apply to your situation and follow the recommended instructions for addressing them.
Please, post back here w/ any questions at all you have, observations, comments, what you've tried in addition to changing the cartridge to correct this issue and the results.
We'll continue to work w/ you until the issue is resolved or diagnosed.
Thank you
BJ @:)
Posted on Apr 17, 2008
  • 3,037 Answers
It sounds like you print heads are dirty
How To Clean A Dirty Print Head
When it comes to printer issues, there are few things as frustrating as expecting a clearly-printed document and ending up with something that looks like a cross between a Picasso and a Rorschadt blot. If you notice that the print quality of your documents has decreased considerably or if you are bringing an old inkjet out of retirement, you need to clean the print head to ensure you’re getting the best from your printer. brother fax machine mfc #4828c - 01173482.jpg
A dirty or clogged print head will hinder a regular flow of ink from the ink cartridge to paper.
The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge’s nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head opening and cause it to print poorly.
pixblue.gif Clean It With Software
There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printer’s software that will actually clean your printer for you. We used a streaky Canon BJC-80 for our testing, and the driver we installed on our system for this inkjet had quite a few maintenance options. (Keep in mind that the process for cleaning your specific printer’s print head may be slightly different than what we’re describing here.) To check these out in Windows XP, click Start and then Printers And Faxes. Right-click your printer and then Printing Preferences. This displays the Canon Bubble-Jet BJC-80 Printing Preferences dialog box, which houses various layout and print-quality preferences, as well as the printer’s maintenance options. Click the Maintenance tab to view what your printer can do from a software perspective. Our printer has two cleaning modes—Cleaning and Deep Cleaning. Cleaning isn’t quite as time-consuming as the Deep Cleaning mode, but Deep Cleaning mode does a more thorough job and can resolve some issues that the normal Cleaning mode can’t. Just click the proper cleaning mode to start it and let the cleaning process run its course. You may have to do this a number of times to get the print head clean.
If you don’t see a maintenance tab, it doesn’t necessarily mean your printer doesn’t have a self-cleaning function; it just means that it doesn’t use commands from your computer to do it. For instance, on the BJC-80 you can also start the cleaning process by holding down the Resume button until you hear two beeps. Check your printer’s manual for ways to clean your print head.
Some software bundles that come with printers have cleaning functions that you can use to clean your print head.
If the built-in cleaning functions don’t seem to do the job, there are a few ways to clean your print head manually. Some swear by isopropyl alcohol, while others believe in just plain ol’ water. When used correctly, either can help your printer perform better.
First, remove your ink cartridges from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Some printers, such as many Canon models, feature removable print heads that give you easy access to the print head and its nozzle(s). Many other inkjet printers don’t have this feature, so you’ll have to do your best to work around parts in your printer. Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out.
If you have a removable print head, remove the ink cartridge from the print head and take the print head out of your printer. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it’s really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle. This should get ribrother fax machine mfc #4828c - pixblue.gified ink that was loosened during the soaking.
pixblue.gif Don’t Panic
Printing problems happen to us all sooner or later, but it’s important not to panic when you realize that something other than an empty ink cartridge is vexing your printer. The next logical step, cleaning your print head, is a straightforward process that can give your printer—and your documents—new life. Though most printers include software or a button that can clean print heads, if that doesn’t work, the do-it-yourself method is simple enough that it’s worth giving it a shot. Before you scrap an old inkjet printer thatbrother fax machine mfc #4828c - pixgray.gifddy printouts, give the print head a quick cleaning. It may end up paying major dividends. pixgray.gif
Thank you for using Fixya and please let me know if you need further help
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 1,447 Answers
Try to run the utility cleaning cycles to be exact and try to change the quality option as well. what operating system are you using?
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 17, 2008
    How to clean the nozzles
  • Press Menu/Set key on the control panel.
  • Press the up or down navigation key until MAINTENANCE appears and press Menu/Set.
  • Press the up or down navigation key until CLEANING appears and press Menu/Set.
  • Press the up or down navigation key to choose the color you want to clean, and then press Menu/Set.
  • By the way whats the exact model of your printer?
Why does our brother mfc-j220 won't print after ink refill
Unplug machine and try again. Let it reboot from the start. It should sense the new ink.
Sep 23, 2014 | Brother MFC J220 - multifunction fax /...
Black ink leftside of paper
Black toner leaking, either the toner is low/finished, or drum is end of life.
Sep 04, 2014 | Brother MFC-9120CN Multifunction LED...
How to solve ink absorber full brother mfc-j6910dw
You cannot change the ink absorbers as the machine requires a full strip down as they are located in the base. You will have to give it to a dealer for repair.
Jan 30, 2014 | Brother MFC J6910DW - Multifunction fax /...
I have a brother intellifax 1840c (which is great, by the way). I need to change the ink cartridge & have no idea how to get into it. Is there a latch or button to help open it? Please help.
1 Close the document support and the document tray.
2 Lift the top cover to the open position until it locks securely into
place. If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Open Cover.
3 Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
You can find the procedure on changing the ink cartridges in the user manual, page 12-25.
User Manual can be downloaded:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000335/MFC-3240C_UsaEngUsr_C.pdf
May 25, 2011 | Brother IntelliFAX 1840C Plain Paper...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Unit Waste Lots of Ink
I have had the same problem, so I decided to use the fax only for sending faces. I took the ink out of the machine so
Aug 12, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 420 CN
the brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother.
Feb 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 4820c All-In-One InkJet Printer Logo
318 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
