Question about Char-Broil CharBroil Master Flame Gas Barbecue Grill
My grill has propane but is burning low... can you help?
    Champion:
  • 274 Answers
Try replacing the hose and regulator, easy to do, and not very expensive.
Posted on Jul 12, 2010
Why is my flame low and the others don't light
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jun 24, 2014 | Weber Spirit SP-310 Propane Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Flame is low when turned on highest setting
There are a few causes for that.
1. You are low on propane.
2. Your propane tank is overfilled, and the overfill protection device is restricting gas flow.
3. You have turned off your grill using the propane tank instead of the control valves on the grill. This may also cause the overfill protection device to engage. You can reset this by turning off your control valves on the grill, turn off the propane tank, unscrew the hose from the propane tank, then put the hose back on securely, turn on the propane tank and turn on the control valves.
4. Your burners are very rusty and may be clogged. Clean or replace the burners.
Mar 03, 2010 | Sunbeam Grilling
Second and third burner burns with a low flame. Burner closest to gas supply works as usual.
This problem can be caused by a number of things. Is this a new grill? If not, is this a new problem?
First -Check to see if the fuel hose is bent or kinked.
• Make sure the grill area is clear of dust.
• Make sure the burner and orifice are clean.
• Check for spiders and insects.
• The regulator has a safety device that restricts the flow of gas in the event of a leak. This safety device can be triggered without a gas leak. To reset the safety device, turn all burners "OFF" and close the Liquid Propane cylinder valve. Disconnect the regulator from the Liquid Propane cylinder and wait 1 minute. Reconnect the regulator to the Liquid Propane cylinder and slowly open the valve until the valve is fully open. Light all burners and observe the temperature.
Sep 04, 2009 | Vermont Casting Signature VCS3507N ...
Veranda gas grill - won't light or low flame
One of the major problems with propane gas grills, including the Masterbuilt Veranda, is the pressure regulator. They get to where they do not release enough propane. Some, most, have an adjustment screw that will let you correct these problems. I think I replaced my Veranda regulator with another older pressure regulator from an old grill. Makes you crazy if you don't know this.
Mar 08, 2009 | Masterbuilt SBMPG3 Veranda Steel Grill
Grilling Logo
169 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
