Question about Sony BDP-S360 DVD Player
On my Sony BDP-S360 DVD Player, I cannot select HDMI on the setup menu, i can only select component, or standard. Everything is hooked up correctly. the DVD player works fine off of RCAs except for a horrible picture, but when you set the TV to HDMI 1(the HDMI slot the DVD player is hooked to), the TV says cannot find signal. The cable is good, it works fine for my 360. I just don't understand why i cant select HDMI as my output on the DVD, or why my TV is saying no signal.
  • 43 Answers
SOURCE: HDMI not working Sony BDP-S350
With sony products sometimes you have to use sony parts to get it to work. I would suggest to buy a sony HDMI cable and see what happens if that doesn't work then take the player back to the store because you got a faulty player.
Posted on Jan 08, 2009
  • 4090 Answers
SOURCE: CAN WE UNLOCK A SONY BDP-S360?
You can try this one
1)No disc in tray
2)press "HOME" key on remote control
3)press number keys "1389310"
Please rate my help++++Thanks for using FIXYA
Posted on Nov 24, 2009
SOURCE: how can I unlock the DVD player Sony BDP-S360
hoe to unlock my sony slv-D370P region code
Posted on Dec 10, 2009
  • 290 Answers
SOURCE: I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
Posted on Dec 27, 2009
SpideRaY
  • 687 Answers
SOURCE: how to unlock sony bdp-s360 and make it multi
You will require either hacked firmware on a CD-RW or a key sequence input via your remote control or via a PDA with infrared capabilties
http://www.videohelp.com/dvdhacks/sony-bdp-s360/10264
Posted on Feb 28, 2010
I have a Sony BDP-S360 DVD Player, 1080p, that gives me a "Not Supported Mode" on my Samsung 1080i plasma TV. Model # HP-4253. I'm using a HDMI cable which I know is good because I used to with...
The error message you are receiving normally signals that the component you are connecting to your TV is outputting a video signal that is too high for your TV. You mentioned that your TV is a 1080i unit; the player may be trying to send a 1080p signal to it.
Pages 42-44 of your manual describe how to setup your output video mode. It may be that you have your video set to auto. The second column of page 43, just under the table labeled BD-ROM 1080/24p Output, describes how to press HOME to display the home menu, and then change the BD-ROM 1080/24p Output setting. You should be able to turn this OFF, and your picture should then come up, as the player will automatically lower the resolution until it finds one that will work.
If after lowering the output resolution you still receive the message, then there may be a problem with the Video Output circuit of the player. The player should be able to communicate through the HDMI cable to find the proper resolution. IF defective electronic components are stopping this from operation correctly they will have to be replaced. If you still have a warranty left they should cover this cost.
If you don't have a copy of your manual handy you can download a copy at the following website:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=BDPS360
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 21, 2011 | Sony BDP-S360 DVD Player
I have gained a sony BDP-S360 Blue ray disc player, but without manual. What are the main parts necessary to adapt this equipmament on my TV? Which cable connections?
start from depending on your tv with hdmi-RGB-s-vid-component that is a little list starting from best to worst just match it up with your tv until you get a color fit and this will rule out best picture too then set tv input accordingly :)
Jan 01, 2011 | Sony BDP-S360 DVD Player
Getting a serial no.
YOU CAN TRY LOOKING IN THE DVD PLAYERS MAIN MENU, SOME COMPANIES PLACE IT THERE.
Feb 21, 2010 | Sony BDP-S360 DVD Player
I have sony BDPS360 how to reset to factory settings
You can select the Resetting option from the Menu of the Blu-ray Player. Please refer page # 53 of the Manual of the Blu-ray Player.
Jan 18, 2010 | Sony BDP-S360 DVD Player
SONY bdp s360 wont play from the menu screen
Could be as simple as a fingerprint or smudge.Give the disk a good wipe with a cloth like the ones for cleaning spectacles and retry.
Jan 16, 2010 | Sony BDP-S360 DVD Player
I have a sony bdps360 i need to reset the res from 1080p to 1080i i need HELP
You can select the “HDMI Resolution” of the Blu-ray Player is set to “Auto,” “1080i,” or “1080p” in the “Video Settings” setup. You can refer the page # 43 of the Manual of the Blu-ray Player.
The audio on from my sony BDP-S360 sucks. Its low in some spots then way to loud in others, and on some movies I have to have the volume turned up almost full blast just to hear what is being said...
Check the audio settings in the setup and see if HDMI is set as the default audio output, you may also be able to adjust the type of digital signal passed to see if that makes a difference.
Failing that run an analogue (red and white) cable to the TV, it should have one set dedicated to one HDMI input.
This is kind of a weird problem and would indicate either a defective BD player or defective TV.
Hope this helps,
Jan 06, 2010 | Sony BDP-S360 DVD Player
On our Sony BDP-S360 DVD player, when we watch movies it keeps flashing a white bar across the bottom of the screen or flicker of white every once in a while.
you might have a loss connection?
what kind of cable are you using ?
hdmi / component / composite?
unplug the power cord to the ac outlet for 30 secs. and plug it in back. this is to refresh the unit.
turn on fan on the configuration of the unit ...
please read the operating manual ...
Do you know the sony bdp-s360 remote code?
2338 worked for my uverse remote bdp-s360
Dec 27, 2009 | Sony BDP-S360 DVD Player
Sony BDP-S360 DVD Player Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
