Sony kp-53xbr45 please let me know step by step how to enter in convergence service mode thank you
  • 6,993 Answers
follow the below steps:
To Enter Service mode With the tv off and the remote in tv mode, press the following keys:[DISPLAY],[5],[VOL UP(+)],[POWER]
The tv will now display "3D-COMB" in the upper left hand corner.
Press the [2] or [5] keys to move up or down through the adjustment categories until you see "PJE" in the upper left hand corner(note that the letters will change to a different font).
Next press the [6] key twice, this will bring up a grid (crosshatch) without video behind it. When I refer to the [CENTER] key, It is located in the middle of the directional arrow keys on the remote.
When cursor is white, you can move it to an adjustment point using the arrow keys. Once you press the [CENTER] button, the cursor will lock to that adjustment point. It will now change to one of three colors ; Red, Green, or Blue. The color of the cursor will be the color you are adjusting. To change the color press the [3] key only when the cursor is locked to an adjustment point, pressing the [3] key when you are in navigation mode will have no effect. By Pressing the [CENTER] button again will switch you back to navigation mode.
To save your changes press the [MUTING] then [ENTER] keys on the remote.
Also, your tv may or may not have different convergence modes that you will have to adjust, if your tv is a hi-def you will need to converge the hi-def mode as well, With the cross hatch up you can press the [DISPLAY MODE] key to switch between the different modes. Make sure you save your changes before changing picture mode or your changes will be lost.
style="font: 7pt 'Times New Roman'"> On tv's that have different screen modes, you can try to copy the settings from the full mode once you have saved the setting by pressing [MUTING] then [ENTER] . To do this select the "ALCP" mode then change the data to "01" then press [MUTING] then [ENTER] again. the data from the full mode is then copied to all other modes. This procedure works for the "RA6" chassis, this procedure may be different in different models
Additional Information:
  1. Save changes often.
  2. The green crt is used to align the other two colors. If you need to get the grid straight, straighten up the green completely before adjusting the other colors. An overlay may be needed if the green is way off.
  3. After adjusting a point, you may throw another point out of convergence, Check for this.
  4. Start converging in the center and go out, don't start on the outside you will be fighting the convergence if you do.
  5. Avoid the tendency to adjust the worst point first, most likely one of the other smaller adjustments will get that badly converged point very close to where it needs to be. By adjusting that badly converged point first, you can throw off a well converged point somewhere else.
  6. If you are at the edge of the screen adjusting a point there, look at the opposite edge of the screen, you can throw a point off on the other side if you over adjust.
Good luck.
Posted on Jul 07, 2010
  • joaorocha73 Jul 08, 2010
    this tv dont have pje only newer models came with pje this one is 1997 model not hd on it
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
Tip
Sony KP-53XBR45 Service Manual Download
Download Sony KP-53XBR45 Service Manual
Would you like to download a free Sony KP-53XBR45 Service Manual?
Have you lost your Sony KP-53XBR45 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-53XBR45 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-53XBR45 Service Manual documentation.
I hope that helps.
___________________________________________
on Jul 04, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 04, 2010 | Sony KP-53XBR45 53" Rear Projection...
Need part # KP-53XBR45, convergance IC
The convergence ICs are STK392-010, the locations are IC1601 and IC1602.
Apr 18, 2010 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-53XBR45 i have a bad convergence board. Do I fix it or replace it. Where is the part available
Replace convergence out ICs to get it fixed.
You can replace these chips if you can replace parts in circuit board with proper tools or ask local tv tech.
Required ICs are available with Part Store.
Thanks.
Mar 19, 2010 | Sony KP-53XBR45 53" Rear Projection...
Color yokes for KP-53XBR45
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Dec 19, 2008 | Sony KP-61V90 61" Rear Projection...
Pip
Please download user manual of Sony KP-53XBR45 and get reply of all your questions about tv.
Regards,
Sep 19, 2008 | Sony KP-53XBR45 53" Rear Projection...
Red light blinkin on the sony kp-53xbr45
Check convergence board for possible blown fuses.
Dec 12, 2007 | Sony KP-53XBR45 53" Rear Projection...
KP-53XBR45, Sound OK, but no picture
You may have a bad convergence... short will shutdown your HV circuitry leaving just audio?
It has no bulb to change?
Oct 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-53XBR45: Concave Picture
try a system reset
turn tv off,
on the remote
display, 5, vol+, power
when set turns on press 8 then enter.
tv will turn off, then press tv on turn turn back on.  See if this helps
Sep 25, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
277 people viewed this question
Top Televison & Video Experts
