Washing machine won't spin or drain, have already checked pump & cleaned filter, any other suggestions? Thanks Kim
    Champion:
  • 274 Answers
Take clothes out put in drain-max and let it soak for 1-2hrs. now run on heavy duty hot water may have to run twice.
Posted on Jul 05, 2010
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
The machine won't go into spin cycle
Hi badams1,
Kind Regards
JEDEMEYER1
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Kind Regards
JEDEMEYER1
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
JEDEMEYER1
Aug 01, 2011 | Samsung Washing Machines
My washer will not spin, it sounds like it's trying to spin but it won't spin and if i turn the barrell by hand it spins so it's not frozen or anything. Any suggestions?
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washing machine won't spin. i've cleaned the water hose filter and the pump filtre.
Hi eddyloz2000,
Kind Regards :-)
Jul 18, 2011 | Washing Machines
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
