Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and On LED flashes very quick). If I try just to Drain, same problem, it drains all the water and them stops with an error (Delay Timer flashes and On LED flashes very quick), seem to me that the pump does not stop working on that stage. We had a problem last time we run it, I found a collar and a coin in the pump, and I thought that was the reason, but after I removed it, the problem still happens. How can I fix It? Is there any water sensor level, or no water sensor that could be broken? Is the pump permanent damaged by that jammed coin? Ou could it be something else? Please help us, we are starting to stink now!
    Champion:
  • 274 Answers
Its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Posted on Jul 05, 2010
  • eduvilla Jul 07, 2010
    Thank for that tip.
    I've opened the pump, and it was not jammed. I did run cloro in the machine and the problem persisted.
    When the machine is working, it makes an "electric" smell, like if something was getting hot... I tried to check where the smell comes from, and seem to come from the pump, however the pump still pumps water out of the machine...
  • plante3pups Jul 08, 2010
    You may want to replace the pump,there may be something jamed in the propeler ,see if you can get the pump out and take it to a parts dealer.
Washing machine manuals
You'll find these on line, just type the model number into google.Make sure to use the manufacturer's site, not a proxy.
Jul 23, 2014 | Ariston Technologies Washing Machines
Ariston avl 95 user manual
will not drain or spin after wash cycle...why?
Oct 18, 2010 | Washing Machines
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Ariston washing machine front loader model number BS1400 error message f-05 stops program and wont spin have unscrewed plug at bottom of machine to drain and started fine after that working for a little...
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
Apr 11, 2008 | Washing Machines
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
New Ariston wash cycle
This is exactly the way the systen is designed to work. It uses very little water so the machine sort of flips the clothes over and lets them soak, then flips them again. Every thing is fine as as it should be.
Feb 07, 2008 | Ariston Technologies AWD121WH
Ariston LBE12X will not fill
depends which program you started with if you started with drain or spin then the humming noise you heard is the pump energised but jammed. remove the filter again and check nothing stuck in the pump impellor - bits of bra wire are the favourites if you started with a wash or rinse program, the humming noise is the inlet valve energised but no water coming thro. check water is turned on and hoses not kinked
May 22, 2007 | Ariston Technologies LBE12X Ariston
Washing Machines Logo
766 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
