Question about Lexmark X3470 All-In-One InkJet Printer
Paper jams,i have't used more than three times,can;t find my book.
  • 149 Answers
It might be a problem with your paper feeder . its a mechanism that take sin the paper , consult a technician and it will not cost you much.
Posted on Jul 05, 2010
The orange light flashes three times and it cant print and there's no paper jam
Did you remember to open the door for the paper to exit? Otherwise, if there's no paper jam check the paper path for debris; the sensor(s) might be gunked up.
Mar 03, 2015 | Canon Office Equipment & Supplies
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
How do i fix a paper jam on my printer?
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Hope this helps. :)
Oct 02, 2010 | Office Equipment & Supplies
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Paper jam(Canon BJC 3000)
Try to open the printer cover and look for tiny paper shreds that might got stuck between the rollers. Also if your printer has a sensor, there could also be a tiny piece of paper blocking it, thus sensing a paper jam.
Aug 31, 2009 | Canon BJC 3000 InkJet Printer
I have a flashing orange light, flashing three times then the power light(green)blinks once, before the three flashes of orange again. I know this indicates a paper jam, but there is no jam. How do I...
You can't reset except by removing paper scraps. Try using an index card and gently push it backwards thru the rollers where the paper comes out to be printed. There are gears on the left side you can rotate to push the card to remove scraps.
Jul 02, 2009 | Canon PIXMA iP1600 Printer
Canon ip1300. Three orange flashes, one green.
Hi emdos,
Did you mean blinking three times in Orange?. Well, the problem is paper jam error occurs in your printer. First, check if any broken paper inside printer. If it so, remove broken paper. If problem still persist, it seems that drive assy broken or paper feed sensor fault. Find more useful article about this below.
Soruce:
Canon Inkjet Printer Forum
Nov 26, 2008 | Office Equipment & Supplies
Paper Jam With No Paper
sensor out of alignment...with a strong light look for a black plastic sensor
Jul 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer jams
i suggest that you replace the feed rollers, cleaning them automatically tells you that they are worn.They should be tacky to pick up the paper, not matter what type.
Apr 13, 2007 | HP LaserJet 8150n Printer
Lexmark X3470 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
