Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Wrong Date date always seems to be a day behind unless synched to PC every 24 hours. A bummer to find this out AFTER you have a baby & have already taken pictures of the birth...the stupid camera recorded the wrong date! Does anyone know how to fix this issue?
  • psrwjr Jun 19, 2008
    What solution???
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
How do I manually set my Eco-drive wr200
Pull crown out 1 click to set day/date, set to one day behind actual date... Then, pull crown out an additional click to move hour/minute hands around to set exact date by hour/minute a complete 12-24 hour revolution if necessary to get AM or PM accurate for the proper day/date. :)
Jul 05, 2014 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Can not set the date and day
I assume you are talking about a day-date Timex. Timex watches do have a quickset feature meaning the day and date can be set without having to simply advance the time by 24 hours to adjust the Day-Date. Not all watches have a quickset, but I'm sure your Timex does. Unscrew the crown from the stem by turning it counter clockwise until it is free from the threads. At this point pull the crown all the way out so that you can adjust the time. That's position 2 the quickset is in position 1 but the tricky part is getting the crown in the proper position to engage the quickset. Push the crown in very slowly while turning once you see the day or date window advance stop turning you are in position 1. Day and date can be set in this position by turning the crown in either direction. If your watch does not have a quickset or you cannot figure out how to engage it you must set the date by advancing the time forward 24 hours. This will make the date window advance by one day. Once the right date is displayed turn the time backwards 24 hours and this will cause the day window to move without affecting the date window. And that's all there is to it.
Dec 31, 2013 | Watches
I plugged in my Emerson Smartset Clock Radio (model CKS2005) and the date is off by a couple. Today is August 4, Thursday, and it states August 7, Saturday. How do I change the date? The date button is...
You have to run the clock back. Press Time/Date and then press up or down after you run it 24 hours the date will change, and the date will move day to day.
Aug 05, 2010 | Emerson Smartset Clock Radio
How can I change the date without turning 24 hours ?
mcdevito75 here, Most day / Date or just date watches with a stem (winder) even if they are quartz have a 2 position stem. Smply slip a fingernail under the crown and lift to it"s first position, this should allow you to change the date with haveing to go the 24 hours but remember the date cahnges at 12--1 Midnite, Best bet, change the date to the date before the date you want then go the 24 hours this way the date will change at midnite and not 12 noon.
Jul 02, 2010 | Festina 6503-I Watch for Men
I nee to set the date. Is always back to the old date
mcdevito75 here, You may have a 2 position stem in your Timex, Slip a fingernail just under the crown and lift to it:'s first position, this should allow you to change the day / date without haveing to go thru the 24 hour cycle. Best Bet, change the date to the date before, then go thru the 24 hours to have the date change at midnite and not 12 noon. If the date keeps falling back to previous, the date wheel maybe loose in that case you can find a small watch repair shop inyour area, but it may be cheaper to replace the watch if this is the case.
Jul 02, 2010 | Timex 27191 Wristwatch
My Dell Axim X5 pocket PC reverts to wrong date
Duh... I figured out that my PC had the date set a month ahead! Not sure how that happened. The Axim was dutifully synching up w/ the wrong date, and so the November appointments didn't register. Thanks for checking.
Nov 27, 2008 | Dell Axim X5 Pocket PC
Setting watch date, day, etc.
yes. i do this problem
Jul 04, 2008 | Watches
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Jan 09, 2008 | Citizen Eco-Drive BL5184-56L Wrist Watch
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
47 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Fred Block
Fred Block
Are you a Casio Camera Expert? Answer questions, earn points and help others
