Question about Whirlpool Kitchen Ranges
Where can i get a oven door glass whirlpool for the model of 3196685
5 Suggested Answers
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
  • 409 Answers
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Posted on Sep 13, 2008
aborcass
  • 2651 Answers
SOURCE: Can't remove oven door from Whirlpool model GR450LXH
the hinges problably require to be "locked" beforer removing from door frame, usually explains in hte manual "how to remve door". if needed, you can input your model number here, to download a copy
http://shared.whirlpoolcorp.com/product_literature/literatureSearchResults.cmd?siteCd=WHRCOM
Posted on Nov 27, 2008
Treefrog15
  • 127 Answers
SOURCE: Condesation build up between glass in door... I
Yes, while the glass is still relatively cool. Many oven doors today have access slots on the bottom of the door to enable you to clean the inside of the glass window. Steam can enter the door at this point and condense on the cooler outer glass.
Posted on Feb 25, 2010
We have a whirlpool built in oven MODEL # RBS305PRS00 There are drippings on the inner glass window that I want to get to so I can clean the glass. How do we get to the glass?
Typically, as in ours, there are screws holding the inner door cover on. Look on the back, bottom or sides. These will hold the inner door on, then once removed, observe screws, typically Philips, holding the glass frames together. Careful not to over tighten the frames when reinstalling or you may crack the glass. Do not use a power screw gun either.
Apr 02, 2017 | Whirlpool Ovens
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
How to remove whirlpool oven door and take out glass
Usually the oven doors when opened just slide out of the hinges especially on whirlpool. Once you slide out the door you will have to remove the inner door screws as well as the handle screws and the screws around the sides of the door if there are screws there too. Then you can get to the glass. Then you should be able to replace or clean the glass.
P.S. On some models you may also find screws holding the door to the hinges. If so you will want to remove those too.
Nov 05, 2012 | Ovens
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Need instruction book for range 465, pt. no.3196685, can not understand the sequence to start gas oven . know how to start, get correct temperature, but not the sequence to start timer
I thought you could get answers from the company with out charge, figured it out myself. Would like an instruction book from the manufacturer as a courtsey service. DJ Henry
Nov 26, 2009 | Whirlpool GS460 Gas Kitchen Range
Loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Aug 07, 2009 | Whirlpool GBS307PR Electric Single Oven
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
