Question about Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue PC Notebook
Toshiba Laptop - Startup freeze 40% of the time.
The computer is a Toshiba Satellite L355D-S7815 - Athlon X2 QL-60 1.9GHz 3GB 160GB (DVD RW) 17'' - running 32 Bit Vista Home Premium.
The problem is - 40% of the time the Startup freezes. Is it Vista or the BIOS? Or, is it something else?
We noticed this after IE7 was updated to IE8 - but don't know why there would be any correlation.
Toshiba & Microsoft Websites & Forums do not have good answers.
  • 149 Answers
Its a common thing for a vista based system to freeze after some updates , and my good advice to you is you better dont place too many applications on the startup , and avoid unwanted updating , ie8 is one such thing . if u have an option better switch to windows 7 , its really fast on notebook computers . install only defender updates from windows.
Posted on Jul 05, 2010
Open case how to el1358g
9xejsknreuu9+p8eghor1yaijqaaaabjru5erkjggg==The Two Thumb Screws above and below.
Feb 25, 2014 | eMachines EL1358G-51W Desktop Computer...
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Oct 29, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
My Toshiba Satellite L505DS6947 power light comes on but the monitor is black. I tried taking out the battery and pushing the power button for 60 seconds but that didnt work. Is there anything else I can...
HI walkerkenn
try connect your laptop to external monitor.
if you windows can boot normaly, tht mean your screen display got problems
but if still can't boot that mean you must do the troubleshooting process with one by one on your laptop hardware such as ram, hdd or mainboard ( this work need you prepared more computer skill and compenent to make the troubleshooting process )
regarda
Jan 03, 2011 | Toshiba Satellite L505DS6947 Turion X2...
While running some applications, the laptop will just turn off. This usually happens while running graphics intensive applications like games.
Go to www.computers.toshiba-europe.com input your model number and let it fine updated drivers and Bios.
Hope that helps.
Nov 10, 2010 | Toshiba Satellite L505DS6947 Turion X2...
Hi What is te type of disc installed on ACER Aspire 5022 WLMI 100 GB? What is the rotation speed of this disc? Thks
rocessor - AMD Athlon X2 QL-64 / 2.1 GHz ( Dual-Core )
  • RAM - 4 GB (installed) / 4 GB (max) - DDR2 SDRAM
  • Hard Drive - 500 GB - Serial ATA-150 - 5400 rpm
  • Operating System - Microsoft Windows Vista Home Premium
  • Screen - 17.3" TFT 1600 x 900 ( WXGA+ ) - 24-bit (16.7 million colours) - CineCrystal
  • Optical Drive - DVD±RW (±R DL) / DVD-RAM - integrated ... [ more info ]
  • Sep 04, 2009 | Acer Computers & Internet
    L355d toshiba dvd v1.20.10 region change
    here is how you do it: go to my comp. slect the drive for your dvd rom i.e, "D" whatever your letter might be, right click on it, select properties , again, selcet the drive, and again, select properties, and click on the "region" tab. CAUTION: don't be changing regions too frequently, you can only change it up to 6 times...then,, you won't be able to change it.
    let me know how that works
    Apr 10, 2009 | Toshiba Satellite Laptop with AMD Athlon...
    Toshiba L355D-S7815 - Spilled Juice - Short Circuit
    Flip the lid open and flip the laptop (opened) and set it on a towel or something. It might take a week or a bit more to dry out. But you might be ok once it does dry out.
    Although the best thing to do is to take it apart. And use a safe cleaner for circuit boards like alcohol (not wood alcohol).
    Since you supplied power while it was wet. You could have have done permanent damage to the intergrated circuits. But let's hope not.
    Jan 30, 2009 | Toshiba Satellite Laptop with AMD Athlon...
    Ram Upgrade
    Max speed supported for your mobo is: DDR2-533
    You will have to buy (4) 1gb sticks (2gb sticks not supported)
    To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
    Here is the specs :
    ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
    CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
    Chipset: Nvidia GeForce 6150 LE Chipset
    HD Bus:
    Front Side Bus options:
    Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
    Special notes:
    - Motherboard manufacturer's name: ASUS A8M2N-LA
    - HP/Compaq name: Nodus-GL8E
    NOTE: *Actual available memory may be less w/o 64 bit os
    Dec 24, 2008 | Computers & Internet
    Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue  PC Notebook Logo
    167 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
