Question about Power Acoustik GOTHIC OV2-1600 Car Audio Amplifier
Blowen transisters how do i change blown transister's
  • Power Acoustik Master
  • 17,130 Answers
Unless you can test the circuits to determine the failure and check for the predriver stage for any failure do not try to change. You must be familiar with the junctions, the type of the transistors before you try, they could be a complimentary pair driver too. so if familiar buy the same rating, desolder from the pcb, care to see for the correct junction, insert the Base, collector , emitter leads carefully solder and test after rechecking once again. otherwise get help.. Good day
Posted on Jul 05, 2010
What couses red diagonal line and red back ground picture on my toshiba television.
short on crt board check driver transisters on crt board if you want to confirm then switch them with green gun transisters from crt just swich them and see if next coclor show difrent if yes transister bad if not open crt cathode from red side to see if crt cathode shorting
Mar 05, 2012 | Toshiba Televison & Video
I purchased an old Realistic TRC-431 CB. When I turned it on it worked fine, the mic was keyed then the lights went dim and stayed dim. Now the lights remain dim. I checked the two output transistors...
The problem is with your power supply. There should be a big round transister on the power supply this is the power transister. It will be mounted to the power supply case. Replace this transister and try to operaste your radio again. Make sure that the power supply you use is at leat 7 amps or the radio will not operate properly and you will possibly blow the transister again.
Jul 16, 2011 | Radio Communications
IN POWER BOARD FUSE BLOWEN.FOUND MOSFET 2SK 3528 SHORT.NOW WHAT CAN I DO,HELP ME.
The power supplies on this sort of equipment is a safety item. All components that are replaced, and the manufacturers do not supply the components only a complete board, are critical for safety.
If the chopper transister has gone s/circuit, that was caused by an error in the drive waveform. It really is too complicated to explain on a site like this but a blanket change of the driver stage, output stage and control semiconductors will get you somewhere near to a working power supply.
Hope that helps.
Oct 30, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
When we turned on our large screen panasonic tv there was a pop, then no sound. The picture is fine. It is several years old. Not a flatscreen. Large speaker at the bottom.
It sounds like the power transister for the amplifier has blown. Inside, it is usually the largest transister connected directly to a heat sink. It will require the ability to solder (and unsolder) in order to affect the repair. Look up the transister from its code inscribed on the case to find a replacement. Power transisters are usually not very expensive. You can go to this link to see what a typical power transistor looks like.
http://innovision-group.net/catalog/index.php?cPath=1_37
Jan 26, 2010 | Televison & Video
The volume on my tv is stuck to number 22 it will go lower(quieter) but not higher (louder)
There is 2 transister between Microprocessor and speaker.. See the circuit diagram..Volume + transister is lost his gain,replace the transistor and get it up..
Jul 09, 2009 | Televison & Video
What does EO means on LED of a induction cooker
i have longer induction , problem is EO error on the display..
i changed(IGBT,Fuse,Capasiter) what i do?
Jul 03, 2009 | Cooktops
Casio-ma150,main cirquet board-Q-4 transister deamage
Try emailing CO-Windler@Weltenschule.de. Also visit his website at http://weltenschule.de/TableHooters/index.html. Look at the TableHooters modification FAQ. He has some good info on circuitry and components. I hope this helps somewhat.
Apr 22, 2009 | Casio Music
Moniter
ok if again and again .ur horizontal out put transister open .then take step
firstly check all capiciter connected through Horigental yoke coil.
then chek Voltage of H/O/Tr C B E (C=50to 80 )(B =logic 0r -5v) (E =0 ) If all voltage is ok Then Change ur EHT.
Dec 29, 2007 | HP 98785A 16" Monitor
Red drained out of picture
The red transister on the CRT socket could be at fault. there is 3 transisters on the socket check for the voltages on all 3. If the red is high unplug the socket and see if it normal if not the transister or circuit feeding has a short. If low the same case seneral applies and a resistor feeding the transister is defective or the transister itself is at fault
Aug 28, 2006 | Panasonic CT-32SL15 32" TV
Power Acoustik GOTHIC OV2-1600 Car Audio Amplifier Logo
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
