Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
A whirring sound and leaking water.
We tried defrosting freezer, but we think it is coming from the fridge. We lowered the humidity in the fridge veggie drawer. We also play with the temperature settings as well.
  • 712 Answers
See if the drip tray beneath your freezer is full and if so, empty it. That may be the problem. Also, there is a panel between the freezer and the tray. See, if the path provided by the panel, for the flow of defrosted water, is blocked with ice and if so clear it also.
Posted on Jul 05, 2010
WHY IS THERE WATER LEAKING INSIDE THE REFRIGERATOR
generally water leaks on top mount freezer types when the defrost tube is plugged. The automatic defrost system works to keep humidity from blocking air flow across the evaporator(behind the back freezer panel) If it can not drain you will see it as water dripping from the top of the fridge section and water under the crispers.......Clean the drain tube under the evaporator of ice(poke a hole in evaporator and you are buying a fridge)........hope this helps
Jul 29, 2012 | KitchenAid Refrigerators
GD5RHAXNQ00 LEAKING?
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Maytag Performa side by side refridgerator. Water is leaking from behind the panel on the freezer side of of the fridge. Through the vents on the back panel there is a heating coil that seems to come on...
Sounds like a stopped up defrost drain is the reason for seeing water in freezer. That heater is part of the defrost system and should normally come one every 8-12 hours depending on your models defrost cycle b
Nov 19, 2017 | Maytag MSD2756G Side by Side Refrigerator
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
Puddle underneath fridge on occasion--tube coming down seems ok
This happens when the water from the defrost cycle exceeds the capacity of the pan under the fridge. The amount of water depends upon the door traffic (how many times opened in the day) humidity, and believe it or not, the door seals. If the doors to not seal or close properly, it will allow air, and the humidity that it carries, into the box, and that means more defrost water. You might also check the pan for physical damage that may make it leak.
Feb 02, 2010 | LG Bottom Freezer Refrigerator w/ Swing...
At least once a day water leaks from underneath my fridge. Can't seem to trace it back. The ice maker line and hook ups are ok. I think it may be coming from inside frige but not sure. any suggestions?
When the automatic defrost cycle runs, the refrigerator has to drain about a quart of water into the catch-pan beneath the fridge, where it evaporates.
Look for the drain tube at the bottom of the freezer and make sure it is not blocked. Remove the lower-front kick panel and, of this model has a drain pan, make sure it's installed and not knocked out of position.
Some units use a little plastic bucket instead of a catch-pan, and sometimes these are sized too small so that they overflow easily.
Some fridges have a 'humid/normal' switch which prevents condensation from forming on door seals.
Oct 23, 2009 | Hotpoint HSS25GFP Side by Side...
Need a defrost cycle i think
lots of frost may mean lots of moisture, check the door seals to make sure they are in good condition and sealing well. In high humidity climates interior frost is more of an issue too. If the seals are making good contact and not broken or split it could be a defrost timer or defrost thermostat malfunction. try to catch the fridge defrosting and ensure that the drain pan has water coming into it, a clogged drain will slowly but surely make a fridge ice up.
May 26, 2009 | Magic Chef Refrigerators
Water leaking when in defrost mode
There is a defrost drain hose from the freezer down to the drip pan under the fridge. It sounds like the hose is not tightly connected, or obstructed, or has a hole in it. You should be able to see the hose on the back of the fridge.
Apr 30, 2009 | Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
197 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
