Question about Krups Super Automatic XP 9000 Espresso Machine
Krups XP 7250 leaks clean water from under unit. Was serviced 6 months ago gets very little use,
gandhiforyou
  • 275 Answers
SOURCE: leaking Krups XP4030 Espresso Machine
go to this link http://www.krupsusa.com/Consumer+Services/Services.htm
Posted on Jun 28, 2008
SOURCE: Krups XP7240 leaks
The grind selector knob can be removed with the following steps: 1) Remove screw on side near grinder (do not let the screw fall into grinder, :-) ), 2) use sharp knife or similar to pry off cover with three dots. This should be easy. 3) Now you can rotate the grind selector and see that the white clear plastic does not rotate and the black does. There are two little pieces (one black, one clear plastic) on opposite side from grinder that slide over eavh other to keep this knob 'locked' into place. 4) again with a sharp pointed knife or similar you can separate these two pieces to 'unlock' them. This is made easier by lifting the side of the bean holder by the grinder gently and tipping it up. Be careful not to force anything too much. The black part should pop off. 5) Now you can lift off the clear bean holder.
After this good luck. We made it farther into the machine, but could never get to where we needed to go to fix our problem.
Krups must be congratulated for designing a machine that cannot be repaired and must be replaced with new purchases.
Posted on Jan 11, 2009
falter
  • 245 Answers
SOURCE: No froth
ing it back to store and tell them ur problem....u can ask for repair or a new machine
Posted on Apr 19, 2009
  • 17 Answers
SOURCE: I have a Krups XP 7230 Expresso Machine. Water is...
I have a xp7240 which I believe has the same housing as yours. I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. The valve that leaks is on the bottom of the machine (will cost you a lot of time to get to it. Don't know the replacement price.) Good luck!
Posted on Aug 07, 2010
  • 4 Answers
SOURCE: KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
Posted on Sep 16, 2010
Krups KM4055 won't brew anymore. Only 6 mos. old!
6 months is under warranty. just return that to the store or in the authorized service center... ty
Jun 21, 2011 | Krups KM4055
Leaking Krups XP4030 Espresso Machine
i think it is better if you try contacting ur service centre
Jun 28, 2008 | Krups XP4030 Espresso Machine
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
Krups xp 4050 leaks water under unit when sitting on counter
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 13, 2010 | Krups Small Appliances Espresso Machine
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
May 16, 2010 | Krups XP7230 Compact Super Automatic...
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Krups Orchestro Leaking
This is a common fault on these machines i have replaced every seal on mine and it still leaks,unless it is really bad i would advise that it be left alone.p.s they are a bit of cuckoo clock inside a proper strip and clean takes about two hours and the parts are hard to come by.
Jan 06, 2009 | Krups Orchestro 889 Espresso Machine
XP 2070 Won't Stop Beeping
Okay, I had the same problem, started beeping and lights flashing one day, unplugged it and it was okay for a few days then this started happening more often until the machine just beeped and blinked all the time and would not make espresso. When I called Krups customer service I was told it sound like a circuit board problem and to send it in, yes its under warranty but I have to pay shipping both ways, so I decided to check it out myself. So here is the bottom line and what worked for me, I removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. I found if I ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, I also found that by removing the water tank and turning the system on for a few seconds and running pump dry (not recommended) I could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean. The machine is 4 months old and I was shocked at the amount of crud that came out. It now runs fine and no more blinking, If indeed this is the fix for this you would think someone at Krups would have a clue, but I guess there a useless a the owners manual for the xp2070.
Thanks and I hope this helps.
John
Apr 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Super Automatic XP 9000 Espresso Machine Logo
212 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
