Question about Craftsman 10" Table Saw
HOW DO I ALIGN THE BLADE TO THE TABLE. MODEL #315228410
    Master:
  • 502 Answers
Should be a spin wheel somewhere to alter the cut angle.look underneath it.unplug it first
Posted on Jul 05, 2010
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
Do you know the specs. on motor of craftsman 10"tablesaw model 315228410
Is there a nameplate on the old motor? If so, it should state the HP, speed and direction of the original motor. If not, a 1/2 HP to 1 HP 1750 RPM motor with the same size shaft that will turn the blade the same as the original should work fine. From the online manual, it appears to have an internal start switch, so the wiring should be standard.
Jun 22, 2014 | Craftsman 10" Table Saw
The blade it is not square with the fence?
I would go to managemyhome.com and download a manual for this tool. I used a table saw number and they have detailed instructions on how to align the blade. I used saw number 11329884. Let me know if you need more assistance.
Aug 29, 2010 | Craftsman 10" Table Saw
How do I adjust the blade so that is parallel to the miter slot on my 10" table saw that is about 10 years old?
I fond some model numbers for table saws and I would recommend going to managemyhome.com with your model number and you can download a manual for this tool with detailed instructions on how to align so it is cutting square. I used the model number 11329884 just to see and I was looking at page 55
Aug 28, 2010 | Craftsman 10" Table Saw
Adjust angle of band saw blade to align with fence
Typically the fence is attached to the table and the table can be angled to create a bevel.
Using a square, align the table so it's square to the blade. Assuming your fence is square to the table vertically, you're good.
With most bandsaws I have worked with, there is a positive stop (typically just a bolt - the head acts as the stop) underneath the table so when you tilt the table, you can return it to flat without having to re-square everything up every time. Once you've got things square, make sure to adjust the positive stop too.
Be aware you may still have to compensate for drift with your fence, though.
If this answer was useful, please vote. Thanks!
May 23, 2010 | Black & Decker 14" Hd Multi Cutter Saw
How do you align the motor on an older (JET) JWTS-10 Table Saw. The manual does not go into it and I have looked inside the saw and can't find any way to align. The rear edge of the blade is out of...
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
May 11, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Aline table to blade
align blade and fence to mitre slot.
Jan 26, 2010 | Powermatic 1791227K Model 64 10" Artisan...
Lost manual for ryobi bt3000 table saw i want to align blade and miter slide
if this is an older tool or a new model you will have to contact Ryobi direct at 1-800-525-2579 and they can email you a copy, they don't show this model number online.
Sep 25, 2009 | Saws
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Craftsman 10" Table Saw Logo
90 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
