Question about Pool & Spa
The filter housing of my penair system cracked 180 degrees around the top portion 1 inch above the clamp...I was wondering if you knew why that might happen? My pressure normally runs between 20 and 30 PSI, but I do not know what the current head pressure was when it cracked since I need to replace the top cover and I haven't ran my system through yet. Also some useful infomation: I have an in floor cleaning system, it is a salt water system. Approximately 15,000 gal. The system runs approximately 8 hours a day. My pool is 5 years old as of June 2010. Any info/replacement parts would be appreciated. Thank you.
  • 990 Answers
Hard to say from here but if your filter is not big enough that will do it. If it is DE it should be at least 48 square feet. If cartridge it should be at least 500 sq. ft.
Posted on Jul 05, 2010
Sealed radiator on top - radiator hose has blown off twice - not overheating HELP
aluminum radiator
plastic top and base seal
tanks held in with crimps on aluminum radiator
find a local radiator shop to replace top seal and top plastic part
of that radiator
not as expensive as a new radiator
replace the thermostat
pressure is too much on that crack for any diy repair product
pop off hose at the wrong time =cook the motor
Apr 29, 2017 | 1996 Isuzu Trooper
There is a break in the cord where the clamp is entering the unit of our Majestic IAQS system Filterqueen Lux have tried to get into it but cant seem to get it open! Any ideas?? This unit is approximately...
undo the side clamps so that you can get to the dirt below.
Grab the handle and remove the top portion of the canister.
Take the top portion and to go the table.
Remove all the attachments (if they are even attached).
twist and remove the cap under the handle at the top.
remove the three screws under the cap at the top of the machine.
when the screws are out, pull up on the handle and the chrome top should come off from the plastic cone underneath. all of your wires and switch are under the chrome dome there.
cut your cord about 1 inch from the machine, and re-insert it into the machine making sure you do it safely. Wire connectors and NO TAPE.
Good luck.
Nov 18, 2010 | Filter Queen Majestic Canister Vacuum
I have a 2000 mazda millinia and it is overheating and the coolant is leaking. Could you tell me what some of the problems may be?
Hello, the thermostat on the Mazda Millenia is the heart of the coolant system. The thermostat regulates the flow of coolant to your motor and ensures your Mazda runs cool at all times. The thermostat acts as a valve to allow just enough coolant to flow through the system to maintain the engine temperature. When the engine temperature cools, the thermostat will close and pressurize the coolant. This cycle is what keeps your engine running cool.
To remove the thermostats follow this steps:
1. Pull the hood release latch under the steering wheel. Access the engine compartment to replace the thermostat.
2. Remove the top radiator hose by unscrewing the hose clamps with a flat-head screwdriver. The hose clamp may have a hose clamp requiring pliers. This clamp will have two tabs on it. Pull the tabs together to loosen the hose clamp.
3. Remove the bolts at the top of the thermostat assembly. The radiator hose will stop at the thermostat assembly.
4. Remove the top portion of the thermostat assembly. The thermostat will be sitting in the bottom portion.
5. Remove the thermostat with your fingers. The thermostat is positioned a particular way. Remember the position it was sitting in the housing.
And for installing the thermostats follow the following steps:
1. Place the new thermostat in the housing. Remember the position of the old one.
2. Lay down the gasket around the surface of the housing. Scrape off the old gasket with a putty knife or a razor blade.
3. Tighten the housing back together. You will want the housing snug to help create a seal for the assembly.
4. Install the radiator hose back on the assembly and the radiator. Tighten the hose clamp snug.
5. Refill the coolant level back to full. Some coolant may have been lost during the replacement.
Thanks
Jul 19, 2010 | 2000 Mazda Millenia
No water flowing into ice maker. Water coming out of filter inside refrigerator
The first thing to check is the filter. It may have become loosened during loading of groceries or damaged due to freezing or even age. You should not have to shut the water supply off to do this - but since water is leaking from that area, it might be a good idea to do so first, or place a pot under it. Remove the filter by twisting the housing - most housings have arrows to indicate direction to turn and to align for installation - usually not more than a 1/4 - 1/2 turn.
Once out, inspect the housing of the filter - look for cracks and damaged seals on the neck or of the filter. If any are found, replace the filter. The filter should be changed periodically and if this has been in service for more than 6 months to a year, it is due for a change out.
You could use a mirror to look at the filter holder - there shouldn't be anything foreign there - especially if the ice maker was working fine before this.
Reinstall if it looks OK, or install a new filter. The filter should twist in reverse of the way it came out. You should feel resistance to turning 1/2 way through the turn until it can not be turned any further. Do not force the filter as it will not form a better seal than the 1/4 - 1/2 turn required to fully seat.
A filter can crack open if subjected to temperatures 32 degrees and lower, as the water in the housing will freeze and expand resulting in cracks in the housing. Check the temperature of the fresh food compartment by placing a thermometer capable of reading these temperatures in a cup of water nearest the filter location. Allow a couple hours for the water to assume the temperature of the compartment. Typical fresh food compartments should be around 35 degrees F. Adjust as needed.
I hope this helps - good luck!
Jun 10, 2010 | Frigidaire FRS26KR4A Side by Side...
Looks like the oil is leaking out right above the
oil filter screws onto an adapter housing which also has the pressure sending unit on it (above oil filter). This adapter housing bolts to the block with 3 bolts. if oil appears to be leaking from where the adapter housing meets the block (especially at the rear side of engine near bottom), then you need to replace the siamese o-rings between the adapter housing and the block ($12 part at dealer). remove lowest 12mm bolt and loosen top 2 12 mm bolts(top 2 bolts won't come out unless you drop the engine down, but loosening 1 inch is all you need), replace o-rings and retighten bolts. be careful not to get dirt/grit between block and adapter. just finished doing this to son's 95 2.7 v6 which was leaving an 8" puddle of oil after idling for only 1 minute-worked perfect
Feb 24, 2010 | 1995 Honda Accord
2004 Impala Air Filter Removal
I generally remove the rubber boot behind the filter to the intake housing. should be two hose clamps. Unplug the two wires pluged into the boot and slip it out of the way. They don't give you enough room to get the filter out with. This gives you about 4 inches of extra space.
Jan 16, 2010 | 2004 Chevrolet Impala
2003 Harley Davidson XL 1200 C Sportster It starts and runs perfect when cold.When it warms up to 150 degrees at wide open acts like it is running out fuel,At 180 does it at half throttle and above,At 190...
That's a strange one. The only things I can think of suggesting are:
  • Clogged gas cap vent. The next time is starts running poorly, remove the gas cap briefly and see if things improve. If so, then the cap is not venting as it should.
  • Moisture trapped in float bowl. Drain the contents on the carburetor float bowl into a clean container and check for dirt, rust, water, or anything else that doesn't belong there.
  • Dirty fuel filter. If there is one, replace it.
  • Air leak between carb and engine. Check tightness of clamps and manifolds for cracking. WD-40 sprayed around those areas with the engine idling will help detect any leaks.
That's all I can think of. Please let me know if any of my suggestions fixed it.
Dec 09, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Just wondering where the gaps should be on the top 2 rings.
Not sure if this is what you are asking for but the gaps have no specific place other than never being in line with each other, They should be at least a quarter turn around the piston from each other
Sep 14, 2009 | Garden
Whirlpool ET18NK fridge does not get cold but freezer is ok. The freezer portion is around 15 degrees, but the fridge wont get colder that about 53 degrees. The house was empty for about 6 months, and we...
If the fan is frozen this would be cause because something in the defrost system is bad. Or you could have a open motor. Make sure the door gasket is sealing.
Mar 08, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
High idle on my 1999 Saturn SL1. The mechanical screw on the idle cam is at its minimum. The car idles at 13-1500 rpms .
Clean the Idle Air Control Valve. It's on the throttle body below the Throttle Position Sensor. Worked for me! Good luck.
Sep 11, 2008 | 1999 Saturn SL
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
