Question about Nintendo Wii Fit for Wii
Can't sync remotes. - Nintendo Wii Fit for Wii
    Problem Solver:
  • 5 Answers
You have to go to the settings to sync your remotes and it would be under sync
Posted on Jul 05, 2010
    Genius:
  • 1,340 Answers
You have to open the battery compartments for your remotes and also the large door on the front of the Wii console.Hold the red sync button on the remote and console at the same time for a couple seconds,also make sure the remote is pointed at the motion sensor bar.Do the same for the other remote.
Good luck and game on!
Posted on Jul 28, 2010
Sync wii controller tmart
t is possible that your Wii remote has "lost" its sync. You can clear all previous synced Wii remotes with your console and reconnect the ones you are using. Power off the console and unplug the power cord for a few seconds. Plug the power cord back in and turn the Wii back on. At the "Health and Safety" screen, open the small door on the faceplate of the console. Hold the red sync button for at least 15 seconds. All previous syncs have been removed from your console at this point. This process does not need to be repeated to re-sync each remote. Take the first Wii remote you wish to sync and remove the door to the battery compartment. Press and release the red sync button near the batteries. Quickly press and release the red sync button on the console. The lights on the remote will flash and then illuminate the light that corresponds to that remote's position (1, 2, 3, or 4). Repeat this process for each Wii remote in any desired order.
fix it. God bless you
Apr 05, 2013 | Tmart Nunchuk Game Controller for Nintendo...
Want to reset my garage remote control to sync with garage base
Garage doors will either have a manual sync. On the side of the main unit where the lights are you may see a bunch of toggle switches. These are the manual switches to configure your doors "code" Otherwise the door will be digital sync. In this type you will usually press and release the sync button on the garage door unit then press and release the sync button on the remote.
Dec 18, 2012 | Televison & Video
Wii remote won't sync
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This sync procedure must be followed for each additional Wii Remote added to the system.
Mar 08, 2012 | Nintendo Video Game Consoles & Games
How can i connect a nyko remote to my wii
You have to sync the remote with the Wii. First, locate the sync buttons on both the remote and the Wii. The remote's sync button should be under the battery cover. The Wii's sync button should be under a flap near the disc drive. Then press the remote's sync button, followed by the Wii's sync button. Make sure there are batteries in the remote, and that the Wii is on.
Aug 21, 2011 | Nyko Net Connect For Nintendo Wii
I RECENTLY PURCHASED A WII GAME SYSTEM. CAN'T GET IT WORKING, FOR THEY WANT AN IMPUT SELECT THAT I CAN'T FIND. I DON'T HAVE MY ORIGINAL REMOTE. CAN YOU HELP ME OUT?
You can Sync any Wii remote with the console here below are the steps
  • Turn on the Wii. The first screen will be the black "Healthy and Safety" screen, which you would usually have to press "A" on the remote to get past. In this case, don't press "A."
  • Clear all synced remotes. Chances are you have several remotes and some of them may still be synced up to the system. Open the cover to the memory slot located just underneath the disc drive. There will be a red "SYNC" button. Press and hold this for 15 seconds. This will clear all synced remotes.
  • Next, open the battery case on the remote. You will see a red button next to the batteries. This is the sync button for the remote.
  • Press and release the SYNC button on the onsole. Then press and release the sync button on the controller. The LED lights on the remote should begin to flash. When the flashing is complete and only one of the LEDs on the remote is illuminated (signifying whether the remote is synced to "player" 1, 2, 3 or 4), the synchronization process is complete.
  • If no lights are illuminated on the remote, take the batteries out and leave them out for two to three minutes. This will clear the remote memory. After the time has passed, reinsert the batteries and follow steps 1 through 4 again.
  • Mar 05, 2011 | RCA Televison & Video
    My wii remote keeps flashin but wont trun on
    You have to sync the Wii remote to the console.
    To sync the Wii remote, turn on your Wii. Then open the back of the remote and press the "SYNC" button. Then open the SD Card Slot cover on the front of your Wii and press the "SYNC" button. Your remote should be turned on if you do this.
    If this problem still occurs even when the Wii remote is synced, your Wii remote might not be working properly. Return it for a new one.
    Feb 21, 2010 | Nintendo Wii Remote Controller
    Wii remotes dont work on the tv screen replaced batteries in both remotes still does nothing
    If you ahve checked for all possible obstructions or made sure tha tyour sensor bar is plugged try to re-sync your Wii remotes. Unplug your Wii for about 30 seconds and then plug it back in. Upon seeing the health and saftey screen hold down the sync button on your Wii console for 15 seconds. This clears out any previous Wii Remote Syncs. After that is performed open up the battery cover on the Wii remote you want to sync and hit the red button, soon after you do that hit the red sync button on your Wii Console. If it syncs properly the blue LEDs on the bottom of the controller will corespond to the # remote it has been synced to. Good luck.
    Dec 29, 2009 | Nintendo Wii Console
    My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
    if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
    Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
    There are two different modes of synchronizing (syncing):
    • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
    Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
    2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
    3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    3. Select the Wii Remote Settings option from the Home Button menu.
    5. Select the Reconnect Option.
    7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
    Sep 22, 2009 | Nintendo Wii Console
    Sync the Remote to Cable Box?
    I'm having the same problem but I do know that you need to sync the remote w/the cable box. My cable box is Dolby, which is where my problem comes in. I can't find a code anywhere to sync the/any remote w/a Dolby cable box.
    Jan 15, 2009 | Televison & Video
    Remotes not synchronising
    Sep 15, 2007 | Nintendo Wii Console
    Nintendo Wii Fit for Wii Logo
    81 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
