Question about Ricoh Aficio MP 2000 Black and White Copier
Eror sc547 what does meen error sc547 for copier ricoh aficio 200?
    President:
  • 623 Answers
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Posted on Jul 05, 2010
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
What meen code sc548 for ricoh1032 and how to cancel this error tank you
Check the Ricoh site. Select your country then look for your model # and search for the error code or knowledge base etc.
http://ricoh.com/support/
Mar 21, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Error sc547 aficio 180
Heat up failure in fuser area. Have tech check thermofuse and thirmistor for signs of wear or dirty
Jan 12, 2010 | Ricoh Aficio 150 Copier
Error code facsimile error red wrench sc547 ricoh aficio 180
there may be a problem with your electric supply(wall outlet) , wrong voltage or power supply bad
Jan 07, 2010 | Ricoh Office Equipment & Supplies
SC547
try to replace power supply
Apr 24, 2008 | Ricoh Aficio 1085 Laser Printer
SC547
Press clear modes, 1, 0, 7, and press and hold the clear/stop key. Enter copy sp. Select mode (5), and scroll to 5810 if it exists, and execute. exit back to the copy sp screen. Press data log (7), and scroll to 7807, and execure. Exit all the way back out to the SC547 screen. Turn the power switch off and on. Not the button on the control panel, but the actual switch. If it comes to ready, great, if not, there is somethong wrong with the fuser.
Error sc547
Did you unplug any other wires by actcident or move some thing? was that problem there before. If not recheck what you did.
Feb 21, 2008 | Ricoh Aficio 450 Copier
Ricoh copier
Must have unplugged the thermister on the coupling connection bank. Reset fuser: Clear modes/ 107/ press and hold clear/stop. Pick copy sp. select mode. exit out of all screens and cycle power.
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
865 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
