Question about Kodak EasyShare Z712 Digital Camera
When i take the battery out my current date is erased and I would need to re-enter. Can anyone tell me how to correct?
  • 4 Answers
Most cameras have internal battery like in a -wrist watch- to store the data. after several years this battery power is lost. I fell your problem is there. Go to a technician and get it replaced.
raviee
Posted on Jul 10, 2010
WGNBPW-710 manual, how do you use the mememory? How do change the date.
Do you mean the Walgreens WGNBPW-710 Automatic Blood Pressure Monitor by HoMedics? If so, the manual is available from HoMedics' support page: http://www.homedics.com/instructionbooks/ . In the product list box, scroll down to the correct model. The direct link to the manual is currently http://www.homedics.com//media/documents/homedics/instructionbooks/WGNBPW-710_IB.pdf .
If this is the correct unit, to set the date and time, press the Date/Time Set button with the clock symbol on the top of the monitor. When the hour is flashing press the adjacent + button to advance the hour to the correct one, if needed. Press the Date/Time Set button to confirm the hour and prepare to set the current minutes and press the + button to advance the minutes to the correct time, again if needed. Again press the Date/Time Set button to confirm this time and the month will start to flash. Press the + button to change this to the current month. Press the Data/Time Set button and this will be confirmed. The day will begin to flash and you can adjust this with the + button. Press the Date/Time Set button to confirm the day of the month and the year will flash. You can adjust this with the + button then press the Date/Time button to confirm the current year.
To scroll through the memory, press the Memory button. Each button press will display the preceding reading from the current one. To clear a memory item, press Memory repeatedly until you reach the reading to erase. Then press both the Date/Time Set and + buttons simultaneously; hold the buttons until you see CLA in the LCD screen.
I hope this helps.
Nov 17, 2016 | Office Equipment & Supplies
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
I have a corded model #77519 phone, how do I change the time and date.
The complete user's manual for your phone is available at the following link:
http://www.retrevo.com/d/df/MANUAL000032975.pdf?doc=532906c5a747ab87134404141e9c11c8&ts=1313184836863&rk=0.17208479428095913
Just use your mouse to click on the link which is the highlighted and underlined text above. This will open a new browser page for you automatically and allow you to download the manual.
Here is an excerp from that manual which describes how to set the time and date:
GETTING STARTED
Caller ID Initial Setup:
After the battery installation and telephone line connection the display will show the Set Language screen:
Set Language
1. Press the Review UP or DOWN button to select the desired language.
E=ENGLISH
F=FRENCH
S=SPANISH
2. Once the desired language is selected , press the ERASE button to
confirm selection.
3. Then the display will change to the Set Time / Date screen and the hour icon will be blinking.
Set Time/Date
1. Press the UP or DOWN button to set the current hour.
2. Press the ERASE button to shift to the minute setting.
3. Repeat steps 1 and 2 above to set MINUTE, MONTH and DATE.
4. Once the correct TIME/DATE is shown on the display, press the
ERASE button to end the setting. Then the display will change to
show the normal status.
Changing The Language Mode and TIME/DATE
1. Press and hold the ERASE button then press UP button.
2. Then follow the steps described above.
Good luck, I hope this was helpful.
Joe.
Aug 12, 2011 | Northwestern Bell 77519 Corded Phone...
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Set the date & time
I'm going to quote dsteele04 on this one (he is a user of this site).
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Apr 21, 2009 | Sharp EL-1801P Calculator
Replaced the CMOS battery now I have a system date confict in win
Try changing it at DOS:
Clic Start--->Run
Type CMD and press enter.
type TIME, it will tell you the current time and will ask you to enter a new one, if press enter without typing any value then no change is made.
Restart and try de updates again.
Good Luck!!!
Feb 26, 2009 | HP Compaq Evo Notebook N620c
Sharp EL-1801P III Calculator Setting Time & Date
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
IBM T30 laptop- replacing CMOS battery
Provided the laptop booted (albeit to requiring bios set up), all is well. The data such as time needs to be re-entered manually, because since the battery is required to maintain volatile memory, when the battery goes flat or is removed, the data is lost. Re-enter all data, including boot sequence (i.e. IDE 0, CD-ROM/DVD)! exit saving to CMOS. should reboot to OS.
Jan 28, 2008 | IBM ThinkPad T30 2366 Notebook
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Kodak EasyShare Z712 Digital Camera Logo
215 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
