Question about Car Audio & Video
I need a diagram to show how to wire the 2 relays for the 2006 dodge charger i own im installing a remote start an the tech notes state that i need to wire two relays with resistors
  • 2,272 Answers
Click on the link below for the 2006 dodge charger wiring locations.
http://alarmsellout.com/support/diagrams/vehicle/DODGE%20CHARGER%202006.pdf NOTE *1 and *2 this vehicle requires a Special Circuit that requires (2) Relays and (2) Resistors, Starter #2 requires a (-)Negative thru a 180 Ohm Resistor and Accessory requires a (-)Negative thru a 610 Ohm Resistor, these circuits must be used for the vehicle to Remote Start, to connect, See DIAGRAM NOTE *3 this vehicle uses a 1-Wire Door Locking System, LOCK requires a (-)Negative thru a 330 Ohm Resistor and UNLOCK requires a (-)Negative thru a 100 Ohm Resistor, some units will also require 2 extra relays, to connect, See DIAGRAM NOTE *4 the DRIVERS DOOR is a PURPLE (-) wire in the WHITE plug Pin 3, the PASSENGER DOOE is a PURPLE/WHITE (-) in the WHITE plug Pin 3. the DRIVERS REAR DOOR is a PURPLE/GRAY (-) in the GRAY 26 Pin plug, Pin 10 and the PASSENGER REAR DOOR is a PURPLE/YELLOW (-) in the GRAY 26 Pin plug, Pin 9. When connecting to an ALARM SYSTME, use all 4 DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM NOTE *5 the REAR HATCH RELEASE will require a (-)Negative thru a 4700 Ohm Resistor and a extra Relay Part #R30-H, to connect, See DIAGRAM NOTE *6 to turn on the parking Lights on this vehicle will require a (-) Negative thru a 2700 Ohm and may also require a #R30-H Relay, to connect See DIAGRAM. click on this link below for more details:-- http://www.commandocaralarms.com/wiring/2006-2007/Dodge/Charger/384.html i need a diagram to - 52bec91.gif
The ignition wire and starter wire are common at the ignition switch when the key is OFF or when the key is turned to be ON position.When installing the remote starter this could cause the starter to engage When the ignition wire is power up or cause the starter to come ON momentarily when the ignition key is turned ON in remote start.The solution is to add a relay to isolate the 2-wires during remote start. Be sure to connect your remote starters start output to the side of the relay going to the solenoid or the car will not crank during remote start. check fig:-- 38f4cbb.gif
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 05, 2010
I need a wiring or instalation diagram for 03 silverado
Download manual from the attached link: https://www.gmupfitter.com/publicat/2004_BB/2003_Beyond_LD_Electric_CK.pdf
http://alarmsellout.com/support/diagrams/vehicle/CHEVROLET%20SILVERADO%201988-2005.pdf
This may help:
http://www.automotivetroubleshootingsecrets.com/2003_Chevrolet_Silverado_1500_4.8L_No_Start_Stall.html
This may help:
2003-2006 Chevrolet Silverado Wiring Diagram:
Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2003-2006 Chevrolet Silverado . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections.
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), SEE NOTE #2 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 BROWN (+) @ IGNITION SWITCH HARNESS KEYSENSE N/A PARKING LIGHTS ( - ) GRAY/BLACK (-) @ BCM, BROWN PLUG, PIN B2, SEE NOTE #3 PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL POWER LOCK SEE NOTE #1, (for BASE MODEL TRUCKS, SEE NOTE #4) POWER UNLOCK SEE NOTE #1, (for BASE MODEL TRUCKS SEE NOTE #4) DOOR TRIGGER GRAY/BLACK (-)(DRIVERS) and BLACK/WHITE (-)(PASSENGER), SEE NOTE #5 @ EACH DOOR MODULE, IN EACH DOOR DOMELIGHT SUPERVISION GRAY/BLACK (-) @ BCM, BLACK PLUG, PIN E, SEE NOTE #3 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK/YELLOW to BLACK (-) @ STEERING COLUMN HARNESS TACH Any wire NOT, PINK, BLACK or BROWN (AC) @ IGNITION COILS or FUEL-INJECTORS WAIT TO START LIGHT DK. BLUE (-) @ INSTRUMENT CLUSTER, PIN A2 BRAKE WHITE (+) @ BRAKE PEDAL SWITCH FACTORY ALARM DISARM LT. GREEN (-) @ DRIVERS DOOR MODULE, IN DOOR, BLACK 26-PIN PLUG PIN 15 ANTI-THEFT GM'S PASSLOCK 2 ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH EXTRA INFORMATION NOTE #1: This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass Module to Remote Start, if you are using a REMOTE STARTER ONLY, use the 791. IF you are installing a REMOTE STARTER with KEYLESS ENTRY you MUST USE the INTERFACE BYPASS MODULE, Part # DB-ALL or XK09, EITHER Bypass will do the Anti-theft and Keyless entry. If connecting a keyless entry only you can use the GMDL-BP. NOTE #2: The IGNITION #2 wire WHITE must be connected to prevent a CHECK ENGINE LIGHT from turning on and to prevent DAMAGE to the TRANSMISSION on this Vehicle. NOTE #3; The BCM is located under the Drivers Side of the dash, the BCM has 6 plugs on it, with the PURPLE plug on the back. NOTE #4: On BASE model truck the DOOR LOCK INTERFACE MODULE is not necessary, the LOCK wire is a LT BLUE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B5, and the UNLOCK wire is a WHITE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B10. NOTE #5: On BASE Model trucks, the Door Trigger wires are @ the BCM, LT BLUE PLUG, PINS B4 and A5. On 4-Door Trucks the LEFT REAR Door is a LT BLUE/BLACK (-) PIN A3 and the RIGHT REAR Door is a LT GREEN/BLACK (-) PIN A2, located in a PURPLE PLUG at the BCM, use all 4 wires and diode isolate when installing an alarm system.
2011-03-28_044351_brakes_lamps_circuit_2003_2500_siverado-dfydxumns33ohqc3bsmt22yf-2-8.gif
collection-fuel-2003-chevy-silverado-wiring-diagram-estimation-information-standard-work-therefore-straight-swapped-dfydxumns33ohqc3bsmt22yf-2-34.jpg
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-53.png
sensor-primary-2003-chevy-silverado-wiring-diagram-fuel-pump-plugs-solid-conductors-important-looking-more-channels-dfydxumns33ohqc3bsmt22yf-2-76.png
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-151.png
Apr 16, 2017 | Cars & Trucks
I have 2006 dodge charger Rt. I brought new battery an starter an have alternator rebuilt an my car still wont crank
There should be power o the small terminal of the stater anytime the key is in the crank position. I would start with checking that. If there is no power you will need to trace that circuit back.
That wire gets power from the starter relay and the relay gets power from fuse 20 in the TIPM (underhood fuse box). The starter relay control side starts at the ignition switch. The pink with dark green wire should have power with the key in the crank position. That power goes to fuse #10 in the TIPM. it then goes to the starter relay. the starter relay is grounded by the PCM.
Give that a whirl.
Jan 20, 2016 | 2006 Dodge Charger RT
Need crossreference wiring on a 2008 dodge charger and aftermarket alarm
This link will get you 2007 which should be same. Good Luck.
http://www.the12volt.com/installbay/uploads/2007DodgeCharger.txt
Nov 03, 2010 | Dodge Charger Cars & Trucks
06 dodge charger o2 sensor wiring diagram wires got pulled out and need pin locations for new connector
on my 2006 dodge 2500 hemi my o2 sensor wires got pulled out of conector need help on were the go back in.
Apr 24, 2010 | 2006 Dodge Charger
Shift indicator light won't work in d, 1, or 2... but it works in p, r, and n. A remote start was installed not too long ago. 2006 Dodge Ram 2500 cummins.
The vechiles start postive wire was tapped by the remote start install, it must be isolated using a relay to prevent feedback on the wire using a relay will solve the issue and return the indicator to normal.
Dec 12, 2009 | 2006 Dodge Ram 2500
1968 dodge charger wiring diagram
resistor gets hot with ignition on
Aug 08, 2008 | 2006 Dodge Charger
Car Audio & Video Logo
346 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
