Question about Saeco Stratos Coffee Maker, Espresso Machine
The brewing unit doesn't click in anymore, seems to not be aligned anymore
  • 1,089 Answers
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Posted on Jul 06, 2010
Machine is not starting right - brew unit gets stuck and if removed in order to reset the alignment of the gearing wheel in the machine, it does not align in order to get the brew unit back in place.
When the upper and lower, dregs box and descale light, are flashing alternatively, this means that either the grinder or the brew group motor, sensors or switches are not responding to the CPU or pwr board. This will need to be brought to a Saeco Service center for repair. I would not attempt to repair without proper working knowledge of the cpu and pwr system.
Apr 30, 2016 | Saeco Odea Giro Plus Coffee Maker
Gaggia synchrony logic making grinding noise
With these removable units, you must be very careful, the circular mechanism that does the running of the Y motion need to be properly alligned. You need to perhaps put the back of a knife in it and adjust until all the parts align, Then it must click in easily. If you have forced it in the clip will not release. you need to rattle it a little.
Sep 02, 2012 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
May 13, 2012 | Gaggia Brera Coffee Maker
After removing brewer group for routine cleaning, i can't put it back. I had performed removal/insertion several times before, no problem. Arrows are aligned. Everything seems fine.
Hi. On the back of the brew unit( unit facing inwards when installing) I think, has a SPOUT which moves up into the injection pipe when its brewing coffee. Well on this SPOUT is a tab that locks the brew unit inposition when your installing it. If that tab has been moved while cleaning, it will not allow you to install the unit. The SPOUT with the tab on it, only moves oh so slightly to be out of position. Dazza REPAIRER
Sep 23, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Son in law added whole beans in ground coffee slot, I replaced the brew group however the machine makes a noise when turing on and no water comes out after grinding coffee. With the old brew group it did...
The notches should be at 10 and 12 approx. If the noise is a clicking sound you have a broken brew drive, and the gears have to be replaced. The brew unit can't compress whole beans and something has to give.
There are to triangles on the front of the brew unit at the round hole where it piviots. They need to be pointing at each other, if the 2 notches are in the correct position, its ready to install
Dec 02, 2010 | Saeco Royal Coffee Bar Coffee Maker,...
I have a cva coffee machine it seems like the brew unit is jamed it makes a buzzing noise like it is descaling itself , I have cleaned it and checked the shoot for alignment it makwes the noise and then...
F73 is a bad brew unit. The cva 4070,4075,4060, and 4066 are designed to use espresso beans.
If you use an oily bean such as Starbuck's french roast, it will clog the filter in the top of the brew unit. If you catch it in time, you can just replace the brew unit. If you run the machine with a clogged filter long enough, you have to replace the brew unit and gearbox together.
Sometimes if you work with the tech support department, they will send you a brew unit to install yourself. If you live in an area that has Miele factory support, you may just want to get a service call. It is very important to rinse the brew unit every 24 hours, and to use the cleaning tablets in the trap door( not the descaling tablets) if not, the coffee oils build up and turn into a tar that will clog the brew unit. They run about 300 dollars so they are worth doing the maintenence on.
Nov 21, 2010 | Miele Coffee System
Gaggia Platinum Swing Brew group will not relocate into position. I have checked all the alignments of the movable parts, but just will not relocate into position. Seems to be a problem with the alignment...
Sometimes if you, turn the machine on without the unit in place it will reset itself, and if on the brew unit the arrow is pointing to the N, then you should be fine, however if the arrow is doing its thing and the gears do not line up then you might have to take it in to get it reprogrammed.
Feb 07, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
Brew unit wont go back in in seaco incanto
There is a flag on the back side of the brew unit. Below the flag are 2 plastic bars that the flag slides in. Push in between the 2 bars and see if the flag will drop. If it does holding the brew unit with your right hand, take your left hand and place it on the bottom left side of the brew unit, then with 2 fingers reach up inside the bottom and grab the bar in the center and squeeze the bar to the left. This will bring the cylinder back into position and align the 2 triangles on the front of the brew unit. Once they are aligned push the lever to the right to lock up the brew unit. Leave the brew unit out, but everything else in place, then turn the machine on. Once
the machine is settled open the door, remove the drip tray and then insert the brew unit, drip tray and close the door.
Apr 26, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Stratos Coffee Maker, Espresso Machine Logo
205 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
